Un plugged and plugged back in no help
SOURCE: I have the Panasonic "The
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door
switch or mount trouble can be caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or
handle as you try to start it. If it works or tries to work, then it's
a door switch mount or door alignment issue.
If
you or someone you know decide to look into it, we have critical
information on safety, disassembly and door switches at our site, and
our link is at our listing here on FixYa:.
If
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
In this case, it's probably happening because it;'s not cooking due to a switch problem.
SOURCE: Setting time on Panasonic NN-CD748B microwave
Panasonic's UK site is here and you can choose Support, then search for spares, servicers, downloads and contact info.
We're
SOURCE: microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
SOURCE: Is there an internal fuse?
there is a fuse, but if this was blown nothing would work, sounds like a capacitor on the control board,just replace the board
