My camera will not hold any date that I set; always sets back to 1/1/2010
You can't change that battery. But there is no need to do so.
Just put 4 recently charged NiMH batteries in the camera and wait 24 hours. The batteries will charge the internal battery. This little battery, should last at lease 10 years.
And only if you put the camera away for a longer time (weeks or months) get out the main batteries.
Never use manganese (Zinc-Carbon) batteries in your camera. They don't give enough power and can start leaking.
SOURCE: Camera looses date & time setting
There is a cmos battery (or a memory battery) on the main circuit that like any battery wears out eventually. If you are familiar with repairing electronic circuits you can get the part from Olympus. There is no part number just "memory battery for C-740" will suffice. Your other two choices are to take the camera to a shop where they can do the kob for you. Don't let them sell you a complete new board, you don't need one. Not for this problem anyway. Or you can ignore the problem and reset the camera (or not)each time you change batteries.
SOURCE: Can't reset Date & Time
What you have to do is go to the icon with the spanner (as shown above) and keep tabbing down. There are more options than just the ones you see in the screen (not just High Power , Auto, Set Tag, On), keep going down and it will show you the other options. You will see the date change icon about 7 or 8 down.
SOURCE: Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
