I have the I Phone 5 and would like to sync my phone to the bluetooth speaker....how do I do it? I have my settings on Bluetooth and it just keeps searching and is not picking up the BT820 wireless bluetooth speaker
SOURCE: my internet speed is slow.I connect it via bluetooth.
Internet broadband connection is much more faster because it is directly connected via physical connection from the modem (typical setup for home use). But now a days wireless internet can now compete with DSL thru a 3G/HSPDA network. In our country we can have a maximum bandwidth of 2.5Mbps using 3G wireless network.
Answer:
Yes you can speed up your connection using your phone as a modem but you need to consider some aspects.
What happen to you most likely is that your are connected using only a GPRS/EDGE. This is equivalent to a dial-up with maximum of 56kbps transfer rate. There is a great gap between the two if you compare it.
I already tested mine with maximum receive/downlink of 2,501 Kbps. I was really amazed.
Hope this things help you. If it does, please rate me.
regards,
-engrkoiled-
SOURCE: can't use bluetooth in lenovo g430 laptop
UNINSTALL ur bluetooth device through
"ON" ur bluetooth through the switch
Control Panel->System-->Hardware-->Device Manager-->Select ur Bluetooth device--> Right Click select uninstall...
Then download the latest driver from
Lenovo Y410
http://www-307.ibm.com/pc/support/site.wss/MIGR-68104.html
You visit this link tips to increasespeedThis link contains the tips about the increase the speed of the internet.you can check Your internet speed in the site ipdetails
SOURCE: I'm trying to connect a clients phone to his
have you search the device through the search option of the blue tooth software
Turn on the Bluetooth
In Bluetooth Off mode, press and hold the Bluetooth button for about 5 seconds until a beep sound is heard and the Bluetooth button backlight flashes blue.
Press and hold the Bluetooth button for about 7 seconds to change to
Bluetooth pairing (linking) mode. The Bluetooth button backlight will flash blue and red. then go to the Bluetooth settings on your phone and select it there and enter 0000 for the default password
Then go to the bluetoothT
