have you checked to make sure the power cord is pushed in correctly?
if the power cord isn't the problem then it may need to be checked by a service tech, because it's not suppose to be running slow just a few months after you bought it.
I would call the people you bought it from & tell them what it's doing & see if they'll give you another one, I've been sewing for 30+ years & I wouldn't keep the machine.
good luck
This Sony model has a scan feature that reads index info on the tape. If the tape is recorded on a non Sony unit, you may have this issue. To turn this off, Hold both the Stop and Reset buttons together for about 5 seconds. The display will now only show the counter, no indexs, and your problem should be resolved. If you lose power, you will need to do this again.
Your brake switch is just hung up. it is located directly above the brake petal and is attached to the petal bracket-use a flashlight and get down low enough to see up under the dash where your brake petal is, it will be hooked onto the petal bracket-just move it, it is probably just mis-aligned.
0) Turn on TV. 1) Press and hold the TV button, light lights up, continue to hold. 2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on. 3) Point remote towards TV the entire time you are programming. 4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent). 5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on. 6) Once the TV turns back on press and release Stop button. 7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
1 Turn on the component you want to program.
2 Press and hold both the TV/DVD/ect button and the power button untill the light comes on and stays on
3 Press the play button every 5 seconds until the device turns off. A bank of ten codes is being sent each time.
4 Press the rewind/reverse button to see if it turns off/on again. Wait 2 seconds and press again until it turns back on.You may have to do this up to 10 times until it searches through the bank of ten codes sent.
5 Press and hold the stop button until the light goes off. This saves the code.
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
