Key on engine off flash codes
First code it's P0320 Possible causes
- Faulty Ignition/Distributor engine speed sensor
- Faulty Crankshaft Position sensor
- Ignition/Distributor engine speed sensor harness is open or shorted
- Ignition/Distributor engine speed sensor circuit poor electrical connection
- Low battery charge
- Faulty Engine Control Module (ECM)
Read more: http://engine-codes.com/p0320_ford.html#ixzz3DcwddSlp
2- P0750 Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty shift solenoid 1 valve
- Shift solenoid 1 valve harness or connectors
- Shift solenoid 1 valve circuit is open or shorted
Read more: http://engine-codes.com/p0750_ford.html#ixzz3DcwoXS73
3- P0120 Possible causes
- Faulty Throttle Position Sensor
- Throttle Position Sensor circuit is open or shorted
- Throttle Position Sensor poor electrical connection
Read more: http://engine-codes.com/p0120.html#ixzz3Dcx3VCPs
4- P0220 Possible causes
- Throttle Position Sensor (TPS) harness is open or shorted
- Throttle Position Sensor (TPS) circuit poor electrical connection
- Faulty Throttle Position Sensor (TPS)
- Fault Electric Throttle Control Actuator (or Throttle Body Motor)
- Accelerator Pedal Position Sensor (APP)
Read more: http://engine-codes.com/p0220.html#ixzz3DcxGUMl4
