Electrical Supplies Logo
Tito Zamorano Posted on Sep 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I put the rings on the piston on a generator sport 1850 plus
Steve P
Level 3:
  • Master 3,912 Answers
  • Posted on Jun 25, 2019
Steve P
Master
Level 3:
Answers
3912
Questions
5
Helped
1307799
Points
15904
Make sure the marking on the rings are facing UP!!
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Sep 20, 2008
SOURCE: no power out put
this may sound silly, but check the reset breaker buttons
Anonymous
  • 37 Answers
  • Posted on Nov 21, 2009
SOURCE: how do i excite a coleman sport 1850 generator?
This unit is capacitor excited, simply pull the terminals from the capacitor and apply 12vdc to the the wires for about 1 second. Then plug capacitor back in reassemble and run generator and check voltages. If the rotor magnetism has been restored and everything else is good you should be producing power now.
There is an alternative way to excite back end but it is a little more dangerous. It involves starting the unit and then applying 12 vdc to either of the 120v outlets for less than a second. This is the best way but it is more dangerous because once the back end is excited the outlet will now be putting out 120 vac. So if you leave your 12 vdc source connected too long you will back feed that source with 120vac. What we've learned to do is to have 2 wires coming out of the outlets with the tips exposed then we take our wires with the 12 vdc source and just brush them quickly against the 2 wires coming out of the outlet.
Anonymous
  • 243 Answers
  • Posted on Feb 10, 2010
SOURCE: coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
Sheldon Dedek
  • 912 Answers
  • Posted on Jun 12, 2010
SOURCE: want to remove the starter recoil from my powermate generator
I got one of these pieces of junk, and had same problem you described.
You will need to remove the end panel to get to the blower housing. You will have to thread the rope through the handle until you have enough slack to remove the rope from the handle. The end panel should now be free to remove entirely.
Find the 3 bolts that hold the blower housing on, and remove them. Once you get it off, make sure that the rope has a knot in it so it won't get retracted into the pulley recoil assembly. Take a screwdriver and push the rope back down into the pulley (that was my problem). Assembly is opposite of taking apart.
Sheldon Dedek
  • 912 Answers
SOURCE: What oil type is used in the sport 1850 generator?
30wt for warm temperatures.
What engin oil is reccomended for the 1850 sport
For most applications I recommend straight 30 weight oil. If you are going to be using it much at below 30 degrees F. then I would use 10w-30. Hope this helps you. Thanks.
2helpful
I have a coleman 1850 sport madel.the unit runs
Due to vibration, it is very common for 1 or both of the wires to fall the switch. Also, due to placement of the switch, it can also fail due to water running down the inside of the generator housing as well.
The lack of DC output COULD possibly prevent the stopping. There are likely fuse(s) between the low voltage winding and a rectifier to generate the DC. SOMETIMES these are even inside the generator cover.
Coleman sport 1850 powermate generator, no fire to sparkplug
1helpful
My coleman 1850 is to loud
Ya, buy a Honda quiet generator, they have a db of about 58, which is very good compared to the other brands. You won't regret it!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
1helpful
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
