Question about Lanier Ld 430c With Feed, Bank, Print, Scan - 124k Copies
How can I connect a Lanier LD430c to a Windows 8 computer so that the scanner work
I just bought a new computer with Windows 8 and I cannot find the driver software for the lanier's scanner
    New Friend:
  • 24 Answers
If SMB scanning is not supported without a firmware update you can set up scan to FTP or scan to email.
Posted on Oct 26, 2014
  • Lanier Master
  • 2,940 Answers
Lanier doesn't seem to have specific drivers for windows 8.1, but you may be able to use the windows 7 drivers, here:
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/e_3000/e_3000en.htm
Posted on Sep 11, 2014
SOURCE:
Cogz
  • 1326 Answers
SOURCE: Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
Posted on Apr 06, 2009
SOURCE: lanier copier ld145 locked up, code is
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Posted on Jul 29, 2009
Gunslinger
  • 62 Answers
SOURCE: Lanier 5527 that is displaying SC541
This is a fuser error, you will need a service call.
Posted on Feb 10, 2010
newport74
  • 58 Answers
SOURCE: Lanier LD135. How do I program it to print
Envelopes thru bypass only....once they are set youl need to set the bypass to envelopes at the machine either thru user tools or by pressing bypass then the # key and selecting envelope or custom size and entering the size of your envelopes.
Back at the computer go into print proprties and select paper souce bypass the printdriver will use the machine settings unless ou tell it otherwise
Posted on Feb 26, 2010
SOURCE: scan routing
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/x22_27/x22_27en.htm
Go to the above site and download your software and a manual, the manual tells you exactly how and what to do.
Posted on May 21, 2010
Can this scanner be made compatible with Windows 8?
There may well be a driver update available. Check on the website for the manufacturer.
Oct 08, 2015 | Office Equipment & Supplies
How do I Remove the hard drive from Lanier printer model number LD445C
It is located behind the panel where your Ethernet cable plugs in. The easiest way is to remove the rear panel. Then remove the metal panel. From there you should be alright on your own.
Oct 14, 2014 | Ricoh Lanier Ld445c Ld435c Ld430c Magenta...
How to print enevelopes without them jamming in a lanier ld425c
in bypass put envelopes in short edge first, push the # button, select size of envelopes and OK it, (needs to be told of size)-Carl
Aug 28, 2014 | Lanier Ld445c Ld435c Ld430c Ld425c Ld420c...
Why after we change the toner it will not print
after refill the toner may be bias charging roler is not proper fiting
or toner cartridge is not proper insert
Aug 18, 2014 | Lanier Ld445c Ld435c Ld430c Ld425c Ld420c...
How do I receive a scan to email
You have to set up the settings in user tools on the operation panel.
Apr 25, 2014 | Lanier Ld445c Ld435c Ld430c Ld425c Ld420c...
Lanier LD425c touch screen does not function
You can try to adjust the touch screen > press the yellow clear button then 1993 & press the stop button three times & follow the display screen. Odds are you are going to have to replace the touch screen, the adjustment will not last long....Good Luck
Dec 22, 2012 | Ricoh Lanier Ld445c Ld435c Ld430c Ld425c...
User manual for a Lanier Copier LD430c specifically instructions to program fax numbers.
Enter the IP address of the copier in the address bar on your browser(to see the copier's web page). You should see a log in button, admin is name and password is left blank. Address book should now appear on left side of screen, click it and add or edit addresses now.
Jun 09, 2010 | Office Equipment & Supplies
Lanier Ld 430c With Feed, Bank, Print, Scan - 124k Copies Logo
216 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
