Hi I have a 2001 Monte Carlo SS with 144,miles I was a mile away going over speed bumps the battery light came on car died I put it in N car sound like it was flooded put it in P same thing turned it off waited a few min than the car started
SOURCE: 2002 Monte Carlo wont start
sounds like your passlock sensor on the ignition barrel is faulty. you will have to go to the dealer to have it replaced because of the programming after replacement.
SOURCE: monte carlo 2001 ss 3.8 V6
is the battery good if it is shorted out it will do this or if the charging system is not working
SOURCE: 2002 Monte Carlo SS starting when it wants
The Starter silenoid is probably what the problem is. And the knocking could that be a loose starter? The two problems doesn't seem connected.
God Bless Greg
SOURCE: 2001 Monte Carlo SS Stalls while driving
its your M.A.F thats the air flow sincer i had that problem also but as soon as i got a new 1 it stopped and ran fine. the part cost about 160 bucks at auto zone and is easy to take off and put on yourself cuz the shop charge about 300 bucks to do a 3 min job but im sure that is the problem with your car
SOURCE: 2003 Monte Carlo SS Hesitates and Dies after running for awhile
The ck engine light should not be ignored, what sensor was shown to be bad ? Have it scanned again and replace the sensor that is bad if it still runs rough you might want to consider a tune up. Plugs, wires, fuel and air filter's and clean the throttle body with some gumout. It could also be the IAC motor Idle Air Control. Good Luck
