the instructions on all new gates belts have that, and Dayco.
G16 a engine or B engine, the steps are different,
the 8valve ""A" engines needs valves lash set very loose.
G16A (TBI engine 8v) black top engine.
http://www.fixkick.com/t-belt/tbelt8v.html
G16B MPI , 16valve (top of engine shouts, 16 vavles)
http://www.fixkick.com/t-belt/16-fast-belt-install.html
the factory pages are there and the maxed out steps way is there.
every itty bitty steps, and the 15 ways to mess it all up.
see those false timing marks
they used the cam cog wheel on 2 engines, one 3 cylinder other 4.
making this tricky, if not alert.
the tracker the GM badged car has a vin that tells what engine,
vin 6 or VIN U
6 is for 16 valves
and a GM RPM tag on the glove box.
LS5 = 8v
LO1 = 16v
ufiche actual
http://www.fixkick.com/specs/RPO/RPO.html
make sure the bottom crank bolt 17mm head is at
94ft/lbs first or BOOM.
