Would
you like to program the Universal Remote that came with your Dish Solo
DVR VIP 612 to control the volume of your receiver, tuner, or stereo
instead of your TV's volume?
The
first step in using the Universal Remote Control that came with your
Dish Solo DVR VIP 612 to control the volume level of your receiver,
tuner, or stereo is to program the remote to control your audio device
using the AUX mode button.
Once
your remote controls your audio device in AUX mode, you probably want to continue to control the
volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish
Solo DVR VIP 612 Universal Remote to control the volume of your stereo
regardless of which mode it is in, follow these steps:
Press and hold the AUX
button until all the mode buttons are lit, and then let it go.
Press the POUND (#) button.
Press the PLUS side
of the VOLUME button.
Press 0.
Press the POUND (#) button. The AUX button flashes three times to tell
you the programming is complete.
Confirm the VOLUME buttons
are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's
volume should change rather than your TV's volume.
Your
Dish Solo DVR VIP 612 Universal Remote is now setup to control the
volume of your stereo regardless of which mode it is in
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control the volume of your receiver, tuner, or stereo instead of your TV's volume?
The first step in using the Universal Remote Control that came with your Dish Solo DVR VIP 612 to control the volume level of your receiver, tuner, or stereo is to program the remote to control your audio device using the AUX mode button.
Once your remote controls your audio device in AUX mode, you probably want to continue to control the volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish Solo DVR VIP 612 Universal Remote to control the volume of your stereo regardless of which mode it is in, follow these steps:
Press and hold the AUX button until all the mode buttons are lit, and then let it go.
Press the PLUS side of the VOLUME button.
Press 0.
Press the POUND (#) button. The AUX button flashes three times to tell you the programming is complete.
Confirm the VOLUME buttons are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's volume should change rather than your TV's volume.
Your Dish Solo DVR VIP 612 Universal Remote is now setup to control the volume of your stereo regardless of which mode it is in
You will not be able to get closed captioning by pressing the cc button on your television remote control. You must turn off the motorola cable box. Yes I did say turn off the motorola cable box. You should be standing in front of the cable box when you turn it off because as soon as it is turned off you must press the menu button on the cable box (not on the remote but on the cable box) right away. If you press menu soon enough after turning it off you will get a hidden menu. You will be able to scroll down to Closed Captioning and choose enable with the left or right arrow. Then just turn the cable box back on and you should have captions.
"210" kind of works, but can't compete with Mr. Bond.
After programming "007", if there are any features of you FiOS remote that do not work on the HK AVR 354 remote, simply follow the HK AVR 354 manual instructions to "learn" additional commands. See the last paragraph on page 31 through letter "e" on page 32.
Cheers, Jeremiah Pattison
Keywords: Harman Kardon AVR 354 remote code to control FiOS DVR PVR STB cable box QIP 6416
Try using the QIP6416 (DVR) model to run it. very similar remote, most remote buttons the same only missing the page and day buttons. Otherwise not sure the problem.
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600 into a Region Free DVD Player There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding CH-DVR 1600 MU
Power Up the unit with NO Disc in the tray.
Press the Setup button on your remote control
Press the 1 button on your remote control
Press the 6 button on your remote control
Press the 9 button on your remote control
Press the 5 button on your remote control
Press the 8 button on your remote control
Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
Exit the menu
Press the Power Off button on your remote control
Press the Power On button on your remote control
CH-DVR 1600 ZU
Press the Red Record button on your remote control
Press the 0 button on your remote control
If you're using the default controls that came with the preset settings for the dvr dish network you selected you need to go in and edit them.
From what I remember, the 520 can go in and learn buttons from other remotes. So you need to go in and look for the setting that allows you to put the controller that came with the dish network up to the 520 and teach it the channel up and down feature. Basically, it picks up the signal from the remote that came with the dvr and copies it making it the exact same as the original remote that came with the dvr.
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
