I unplugged fridge and allowed it to defrost. I vacuumed fan and below fridge. Plugged it in and beam where doors rest shut in middle too hot to touch within minutes.
SOURCE: Whirlpool Side by Side Refridgerator
the heater in the gasket area is on when the unit is cooling (compressor running). hot weather makes unit run more, hence the heater is on longer and gets warmer. Coils under the unit being dirty or many door openings can also cause extra run time.
J
SOURCE: OVERHEATING COMPRESSOR
you can check its starting components. it could be a bad capacitor or a bad start relay. if the compressor starts from cold, it could start right away but as it heats up, it should be able to start also, since after running for a few hours, the compressor will really get hot, it would stop at defrost cycle and re start again after about 30 mins. since it is still hot, if it has a defective starting components, it can not start and that is the time it would overheat.
in any case that the starting components are all ok, then you have a partially burnt compressor. it would run while cold and can not run when hot because the resistance of the wires changes as it gets hot. with this kind of problem, you need to replace the compressor. as you have said, the fan at the condenser is running. if the fan at the condenser is not running, that is also a cause for the compressor to overheats. i hope i was able to help...
SOURCE: freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
SOURCE: Plugged in refrigerator and it's getting really hot on side
I don't think fire is any issue. The unit cools itself by dissipating it's heat on its outside walls. For the moment, the outside is hotter than normal because the inside is also hotter than normal. Both will normalize after a while.
