Could not locate that code in the service manual, sure about it?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
SOURCE: error code c-12cc for Konica Minolta biz hub c-350?
Error code C0520 on Konica Minolta biz hub c-350??
SOURCE: Biz Hub C250 - code error C2551
Ahhh, you must be the same Macdaniel I emailed for clarification a short while ago.
C2551 relates to the Cyan imaging unit, the machine thinks the toner level inside the Cyan imaging unit is low.
Opening and shutting the main front door is the reset procedure. However if this doesn't work you should try the following
Remove the Cyan imaging unit, give it a bit of a shake and then refit.
Experience tells me that the above only works on occasion and you will probably require a new imaging unit. They are available for around £250.
Please be aware that the fault could also be down to a circuit board being defective, but this is less common.
Regards
Taminol
SOURCE: biz hub 6500 has a code c3508 how do i clear it
If this code comes right back do not attemp to clear again, contact a certified service technician and have him or her look at this problem, it deals with fuser the hot part of the machine. Dangerious!!
To reset a fuser abnormality code, perform the following:
1. Power the machine OFF from the main switch leaving the sub switch ON.
2. Press the utility Key and power ON the machine from the main switch.
3. Enter Stop => 0 => 0 => Stop => 0 => 1.
4. Press [03 System Setting] on the touchscreen.
5.Press [01 Software SW setting] on the touchscreen.
6.Press the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
7. Select the bit number of switch 1, using the right up-arrow, 03-1 will be indicated.
8. Press the [Return] key, which is displayed on the touchscreen.
9. Exit Service mode to return to normal operation.
DipSW 3-1 is set to 0 without correcting the cause of the error, a fire may occur.
SOURCE: Biz Hub c250 gives error code 3452
C3452: Pressure Heater Trouble.
Try to reset it like this:
Shut down from the main power switch (the one behind the front cover).
Keep pressed the Utility/Counter button.
Power on while the button is kept pushed.
Release the 'Utility/Counter' button only when you see the 'Trouble Reset' button on the touch screen.
Touch the 'Trouble Reset' button, a small ok should pop up underneath.
Power off, wait for a few seconds and then power on.
