SOURCE: John Deere 14SB mower with Kawasaki FC150V series - Throttle adj.
Hello rfbarrett:
From your Description it Sounds like the Plate that is Attached to the Carburetor (that the Throttle cable Attaches to) Thru Shaft (holds and Moves the Throttle Valve) has Loosened and is Simply Turning on the Thru Shaft and Not Moving the Thru Shaft and Throttle Valve at All.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers 14SB and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: my 14SB John Deere mower will start but then quits
Hello. You have some winter buildup in your engine. Get a can of starter fluid and a helper. have the helper shoot small squirts of starter fluid into the air filter while you run the mower. In just a couple of minutes the starter fluid will clear your problem. Joe
SOURCE: I have a John Deere riding mower with a B & S
Possibly a restricted carb, or float level (if it as one).
SOURCE: my john deere LA120 will only start with a jump,
Your starter may be nearing the end of its service life.
If it is worn down it may require more amperage than your battery can deliver to crank. That is why the extra battery helps. More amps!
You can start your tractor and check the wires to see if they are hot to the touch. That would be proof the starting system is drawing more amps. If it isnt hot then you might have connection problems or corrodes leads.
You can try replacing your battery wires to lower resistance and improve power transfer to the starter. Leads are cheap and available at most car parts stores.
SOURCE: I have a john deere 285 lawn tractor that smokes
It sounds like it is too rich in fuel at full throttle.
Try removing the air filter and running the engine.
What happens?
Ensure that the choke is fully open.
Gary
