hi! there,check leak over the line tube you can determine when you can find an oily wet,if find replace then calibrrate you brake assembly mechanism upon removing tire on front side,remove drum brake so that you can bleed the air present on brake system
check brake fluid on brakemaster cylinder
,filled it with a good brand
of brake fluid to exact level marked on brake fluid
at the backside of your brake assembly
there drain plug to open,use open wrech for adjustment,let somebody pump your brake pedal to compressed fluid ,
until on maximum pressure,,then release fluid on drain plug,this should be done several time to purge air inside your brake system
after air purge out,adjust your brake shoe correspond what adjustment and compantible to your car where convenient to you,
take note proper adjustment and preventing your brake could avoid
you in any collision and accident.regard's and have a nice day careful while you drive.
