Unit works fine with just the batteries but will not work when using the ac cord.
SOURCE: Sony CFD-E100 now only powers up on batteries
The AC inlet needs to be replaced, there are bad solder connections on the PC board for the inlet, or the traces are cracked on the board. I have seen all of hte above over the years for these types of units. The power board can be puirchased for $28.11 using part number: A-1124-986-A from tritronicsinc.com.
I don't have the part number for the actual inlet at teh moment, but I'll try to locate that number for you as well. Check for poor solder connections or a cracked trace first and update this with the results.
Dan
SOURCE: We need to buy a replacement power cord. Where
Radio Shack. Verify on the back on the radio if the connector has two circular plugs or if one is circular and the other is like the shape of the letter 'D' and let Radio Shack know.
SOURCE: I lost the power cord to my Sony CFD-S350. How do
Your local Radio Shack store sells all types of replacement appliance cord sets. Since you lost your cord and didn't just damage it, ideally bring the radio (or a photo of the power jack on it if unable) to the store so it can be matched. There are several different types - and some look very similar - but won't fit properly.
I hope this helps!
SOURCE: Call Customer Service Support 1-8O5-465-751O For Help CFD-S300 Sony Boombox lost power cord
What should be the secondary voltage be on 115 volt primary transformer off the power cord for the CFD-S300
