Answering machine won't stop flashing 'full' symbol, but it has no messages on it
My answering machine won't stop flashing the "F" symbol. It says it is full but there are no messages to erase. Unplugging it doesn't help. How do I fix this problem??
Dear friend,
You have not written about your model no.
Yet if you are sure that you don't have any unread msg, then its happening because your msg memory is full!
Please clear up your msg memory by deleting some msg's .
I am sure deleting some msg will help you.
Regards,
Priyank Abhineet.
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
You can move a message from one mailbox to another. The message is saved a a new message in the mailbox to which it's been added and is deleted from the original mailbox.
1 While the message you want to move is playing press "setup". The system beeps and stops playback, the Message Window displays CP (for copy) and the Mailbox lights flash.
2 Press the MBox button where you want to move the message. The system resumes playing messages in the original mailbox.
There are zero message on the machine, but the machine says "messages full" to the caller after if answers and plays my recorded message. It also flashes "F" on the display. I can't figure out how to reset it so that it will answer my calls. Can you help?
