Front tires tells me how much air in tires but rear tires dosent tell me how much in it information center will tell me etc 46 air but the rear might show o can some one tell me what I should do ( thanks)
Look at the sticker in the driver side door and use that as your bible. that will maximize your gas mileage, handling and tire life. i am thinking 32 psi.
Inside of each tire attached to the valve stem is the sensor that transmits the air pressure to the indicator panel. It is possible that the sensors have gone bad on the rear of the car or that for some reason they were removed when new tires were mounted on the car. The only way to check that out is to have the tires dismounted and check the transmitter on each of the rear tires.
