Heating & Cooling Logo
w
william Posted on Sep 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a haldex 1hp 115/208-230 volt motor ac. i need to make sure i hook it up right for 230 power. the diagram just confuses me and im a mechanic. white wire, black wire, push button switch, and 7
Just need to know how to wire it for 230
LOU
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 124 Answers
  • Posted on Sep 13, 2014
LOU
Expert
Level 2:
Cheetah:
Answers
124
Questions
Helped
44329
Points
159
The spade terminals in the wiring box are marked the chart tells where the color wire goes to what terminal for what voltage then l1 and l2 is the incoming power hookups
2 Related Answers
Anonymous
  • 8 Answers
  • Posted on Jan 21, 2009
SOURCE: Hi I have a farm
there is normally a name plate on the inside of the cover that shows high and low voltage connections without that the connections could be a couple different ways. Have a look Im sure its there
Anonymous
  • 1515 Answers
  • Posted on Apr 09, 2012
SOURCE: How towire a 220/110 7 wire single phase motor to 2 wire plus ground switch
This is very simple, but you need to make sure you have the correct wires in hand. If you are wiring a 220/110 motor, and you are wiring it for 110 use, you will only be using 3 wires. If this motor has 7 wires, most you will need to cap off.All you need to use are P-1/Line 1 is your 110 hot. Cap off T-4, 2, and 5, Line 2. That would be used for 220 volts. P- 1 will go to your hot wire on press. On the new motor, T-8, P-2, and t-3 you say are insulated? You will need a Neutral wire to tie to the other line wire coming from the press. And the 3rd wire will be your ground. So, P-1 is hot to your press wiring, t-4,2, and 5 capped off. T-8, P-2, and T-3 has to be a Neutral wire, I would think that if T-4,2,and 5 are line -2, this would be for 220 volts. You are being confused by so many wires. You will only need to use P-1 power for 110 to press power wire, find which wires are Neutral and a ground that will go to your press wiring.P-1 will go to Red if this is hot to the press, Black to Neutral, and on the new motor you will see what color is ground, normally green or bare copper. 3 wires only. You will only need the p-1 hot, a neutral, normally white but may be black on the new motor, and a ground. Look at the Diagram on the new motor, and it will tell you the combination. P-1, Neutral, ground, and cap off the other 4 wires. I hope I havent confused you more, it is very simple, its just the colors of the wires the are confusing you and the amount. Just remember, you only need to use 3 of the, P-1, Neutral, and a ground.
Shastalaker7
Electrolux Gas Range went through a power outage shows/beeps a F15 code. I cannot use oven. I can use the top.I have to unplug it after each use as the oven light stays on.
The first thing I would check is to see if there is 240 volts AC at the back of the stove. On some stoves, The top section runs on 120 volts and the oven runs on 240 volts. Best of luck to you.
1helpful
Trying to wire a single phase 1HP motor to a standard hot, neutral, ground plug. J10 Black ----] 2 White----] low volt line T4 Yellow---] P2 Brown----] T3 Orange---] T5 Red--------] P1 P
didnt specify to much --generic answer -- sounds like hooking up a heating or cooling unit black and white should be your line voltage use a meter to test your black and white line for 110v if motor is 110v the low voltage lines are control or switch lines that dont go to motor they usually go to a thermostat or transformer
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 • Plumbing
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
What happen with a wrong connection on a single phase 2hp sp motor
I'm not sure which motor you have - the heading shows a 1HP type - yet you talk about a 2HP type. Anyway, the label on the motor should have a wiring diagram. You must have a label on the motor to know how to wire. It may have two diagrams - one designated as "high voltage" and the other "low voltage". Check the label for voltage.. it likely says "120/240 volts". The 120 uses the low volts diagram and the 240 uses the high volt diagram. If the motor has terminals L1 and L2, these will most likely be the point of connection for power - regardless if it 120 or 240, unless the label states otherwise. Unless the neutral connection is specified on the label, it does not matter which L1 or L2 you connect it to.
The other terminals will be required to be connected properly. Motors use these connections or jumpers to set options such as voltage, direction of rotation, speed(s), etc. An incorrect setting here can cause unexpected results as far as speed and rotation, or catastrophic results if you supply this motor with 240 volts but set the jumper for 120 volts.
Here's a link to their catalog with telephone numbers for you to review.
Aircompressor 1hp. 106-174541.how to hook up wires for motor and pressor switch
Unless the wiring has been removed, the pressure switch to motor wiring should be ok. The input AC 115 volt line connection goes directly to the pressure switch. Be sure to connect the line ground connection (green or bare wire) directly to the pressure switch box (green screw). Hope this helps!
I need the wiring diagram for my 10 table saw, I disconnected the motor and the power supp. without marking it first and now i don't know which wire goes where, please help!!
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Need to install power cord to terminals on 220 AC motor
Ok, read the data plate on the motor. Does it have a zero with a line straight through it. That means it's single phase. Also the plate may list two different voltages 110/220ac correct. On the inside of the panel of the box where the cord connects it will have a two diagrams. One marked low voltage, the other high voltage. You want 220ac so follow the high voltage diagram. Since it's single phase the green wire will go to a green screw in the box. The black wire from your cord is positive and the white negitive (actually neutral but shown on diagrams as negitive). The wire coming out of the motor will have numbers on it's casing. Follow the connection points on the diagram. Don't worry if you hook them backwards the motor just won't turn. It won't hurt anything.
Top Heating & Cooling Experts
Paul Carew
john h
