As a unit if possible
SOURCE: How does one change from one collet size to
I just did this on my black and decker router. You need to unscrew the nut that holds the collet and remove it altogether. Then slip out the collet in there and replace it with the new size. Take care to notice how it goes in when you take the old one out. Then rescrew the nut that holds it in place and tighten. My router had three collets and only one of them works for each size, so if it doesn't tighten properly, it may be the wrong size. Good luck.
SOURCE: Collet on Freud router won't release bit
a new collet won't hurt, but you may try sanding down the inside of your existing collet with 120 - 180 grit sandpaper. also, buff down the router bits
any condensation or moisture that may have gotten on these items can cause almost invisible oxidation that you can remove easily by sanding. DO NOT USE WD40!!!
Testimonial: "Tks! Will try sandpaper inside collet. Not sure buffing bits will help, since likelihood of ALL of them having a surface problem is pretty low."
SOURCE: Back in December 2009, I wrote asking why my Freud
Thanks for the follow up....
I'm glad your problem was resolved in the end.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
