If I put the machine on spin only, it still does not kick into the high spin mode. Small load does not change it.
SOURCE: WFMC 3200 WONT SPIN OR WASH
Open machine's rear panel and look for a broken belt and does the motor spins. Let me know with your results and we will see how could we assist you.
SOURCE: Bosch Nexxt 700 spin problems
yes it could be normal if the balance control senses that the load is uneven however the same problem could be caused by a blocked filter or blocked sump hose.
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below)
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: Bosch Nexxt 100 Series Washer,
there is a two year warranty on that unit and yours is about to expire if you have not called a bosch technician first thing to do would be to call service on your unit and get someone to come out always better when someone else pays for the repair then you Im going to post this then look into your spin issue further so you can get them moving on repairing it for you. Thanks Rick
