Vizio does not make 37" plasma TV. for the green line problem, does it happen on all inputs or just when you what TV (cable or satellite)? That line should only be present on some channels due to signal processing compatibility. To get rid of it, you can use the horizontal size adjustment and expand the picture side way.
SOURCE: My 37'' Vizio LCD TV has a green haze and lines on the TV
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
SOURCE: VIZIO P42hd PS42a plasma
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
SOURCE: Philips plasma tv. has green line on left side of screen.
Using your TV's remote control press the right cursor button three times
and it will adjust the Screen to the right and the green line will
disappear. Use the left button if your green line is on the left.
Thanks to:
http://www.tivocommunity.com/tivo-vb/showthread.php?t=319984
