SOURCE: Philips GoGear SA3125/37 MP3 Player Charger cable
Anyway, if you have Motorola, you can use it charger for charging mp3 :) (My Aunt have Motorola mobile phone, and I used her charger for charging my MP3 :)) Sorry for weak English :P
SOURCE: my gogear wont load
You need to update the firmware to resolve the issue, but here are some pre-steps:
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
SOURCE: gogear says ok to disconnect, but isn't charging, how do i make it charge?
hi , enter to the website of philips and download the software and new firmware select first you exact model, next quit batteries of your mp3/mp4 player and press the button (bent arrow) all the time until it detects and connect to the computer and run software and choose repair
SOURCE: my GoGear Mix 4 GB, Philips, hang, I cant open,
Please try this it really works. If you are still facing the problem visit nearest service center.
SOURCE: my philips gogear mix 2gb,no
There is a small tiny hole which is the RESET to the player Use a small office pin to pres and hold as the processor will reset . Also remove or uninstall the gogear on the PC and restart. Now connect the go gear and it will be detected as a new hardware and installed. If not there are errors on the player and to confirm test it on another PC.
