Ok a lot not said here trouble shooting time. does the battery have a full charge "no" put a charge on it. battery wont charge and still wont do a thing dead battery get another one. ok battery charged and all works undo the positive cable on battery, if it still runs "good" if not alternator is bad. hope this helps not much to go on
SOURCE: power door locks & dome lights dont work
hello first thing you need to check your fuses look for listing in your book under fuse panel then look for amperage of fuse it should be numbered in the book as well in the fuse box match the numbers same goes for your dome light goodluck
SOURCE: my power windows and dome light and door locks
what year? But the trans shifting should have nothing to do with door locks
SOURCE: power windows quit working plus dome light and
check for blown fuse[s] in the fuse box behind the panel under the dash on the drivers side. there is a legend inside the box cover.
SOURCE: i dont know where the
There are 2 fuse boxes / fuse panels in nearly every Ford product: one
directly above the driver's left foot (when the driver is actually
sitting in the driver's seat). The other is inside the engine
compartment, on the right side - contains high current fuses.
The window fuses should be in the fuse box inside the car. It appears that fuses #10 (30AMP), #11 (15AMP) and #26 (10AMP) are the
only relevant fuses associated with the power window circuit for this
vehicle, according to the Ford wiring diagram. Hope this helps.
I think replacing fuse #26 should fix both the windows and the dome light.
SOURCE: ford explorer winsheld wipers and power windows
