Televison & Video Logo
A
Anonymous Posted on Sep 08, 2014
<!-- from fixya rte -->How do you un-mute tv settings - Televison & Video
Steve
Level 3:
  • Master 3,290 Answers
  • Posted on Sep 08, 2014
Steve
Master
Level 3:
Answers
3290
Questions
Helped
1127403
Points
12184
Most TVs will un-mute when you press the mute button again. Each press it - you cycle "mute to un-mute" and "un-mute to mute".
Some STB (set top boxes) like those from some cable tv companies provide volume changing capabilities. If both the TV and STB volume is set very low or mute - no sound will ever be heard thru the TV speakers - so make sure both are set to a value the is audible.
Lastly, make sure the TV is set to use the speakers that are connected. If it supports external speakers, but you do not have those connected, be sure that the TV set up menu reflects that only internal speakers are to be used. If you have external speakers - make sure they are indeed connected and that the wires have not been damaged - or try with the internal speaker option instead.
Di Patel
Level 2:
Sergeant:
  • Expert 266 Answers
Di Patel
Expert
Level 2:
Sergeant:
Answers
266
Questions
0
Helped
75909
Points
768
Try pressing the mute (speaker symbol with diagnol line) or just press up/down volume button
2answers
I don't know where I control the volume on a TCL Roku TV Model 55R512 Remote. The TV is in mute mode and I can't unmute it.
On some TCL Roku TV remotes, pressing Volume Up un-mutes the TV. Pressing Volume Down enough times will mute the TV. (A few models have a physical Mute button on the side of the TV.) If the TV speakers have been disabled, you'll need to go through the Settings or Options menu instead. (If the unit was used with a sound system, that would be common.)
For more specific information, please add a comment with the TV model. Usually the remote instructions are in the TV documentation. I can't find any TCL TV documentation that lists the 55R512 remote.
I hope this helps.
1helpful
The my disH remote has the mute off . The Samsung mute is on. I can't find how to turn it off
Enter the audio setting to your TV. There you can see the un-mute option to TV. Select it; and change the mute function.
google.com/+GopakumarGopalan
Our tv is on mute and when we try to get it off mute it gives us the message that it's not available in current mode. How do we get it off mute?
Check in which mode the TV is set now. You can get it by pressing the input selector button on the remote. Select the mode to "TV' and try to un-mute the sound.
Tv turns on but has no sound
I'm going to have to say un-mute it and make sure audio is set to TV speakers if you do not have a receiver .
My soyo tv remote fell and does not want to turn on tv
The audio is not working. Tried to mute and un-mute and that's not the issue.
How to un-mute the head set
To toggle your headset's muting fuction on and off, press both volume keys. By the way, you can download its user guide from this location.
Cheers! Carlos
Televisor
Decime el modelo de televisor (numero)
Un detalle tonto no pero Fijate que los parlantes no esten en MUTE
Acordate que el TV debe ir en canal 3 (ponelo a mano desde el TV)
Cuando tengas imagen, TODO A MANO prende y apaga la caja digital
Tambien apreta en el DVD o VCR la tecla TV/Video
Prende y Apaga tu DVD/VCR en esa misma operacion
Que pasa si pones una pelicula? No se escucha pero se ve?
Chequea el sonido desde el menu de tu tv, fijate sino hay un boton que dice MUTE
1helpful
2answers
Can't get rid of subtitles
Often the subtitles are a function of the TV. Check the menus on the TV and turn them off there. Sometimes merely muting and un-muting the TV is all it takes. Other times, you have to go into the settings.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
