Please follow the instructional video provided below on how to reset your tablet to factory default settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
SOURCE: Need User Manual for hannspree tablet
This is the english version. Http://www.hannspree.com/HSPV3images/Downloads/TabletPC/UserManual/SN10T1/HANNSpad(SN10T1)_UM_EN_v1.0.pdf
SOURCE: i have a hannspree SN1AT71WEE301 i cannot connect to the camera is there an easy fix.
Assuming the built in cameras are the issue,
\are you using the provided software ?
You can try to update the ROM and / or drivers for those devices.
sometimes an update may not install properly and re-updating the ROM and / or specific device drivers would solve the issue
Attached is a link for the English device manual:
http://www.hannspree.eu/uploads/Downloads/TabletPC/UM/SN1AT71/SN1AT71_User-s_Manual_EN.pdf
If you are having difficulties with the device recognizing an attached camera device, you may need to go to camera device manufacturer website and download the appropriate drivers to match your tablet device operating system and connection type.
Ex: USB driver for camera connecting using a usb port connection. Also ... confirm proper cable is being used.
Ex: Some connections require 5 contact point cables, others only 4 contacts - this will be determined by your devices.
I hope this was helpful.
Sounds like a boot loader failure
1. Power off the device. (Make sure to plug in AC power.)
2. Press and hold Volume Up(+) button and Power button at the same time for 5 seconds, and release both buttons to enter system recovery utility.
3. Press Volume button to select " wipe data / factory reset " and press Power button to execute
4. Press Volume button to select " Reboot System Now "and press Power button to execute
Hannspree Customer Service at:888 808 6789 (1-909-992-5025 outside of the US); Mon - Fri: 6am - 6pm PST / PDT.
