2 years old, just all of a sudden has a mind of its own. No control on on/off, volume, stations etc. Have to disconnect wire to turn off. only 1 station works. Tried changing fuses, checked wires...help
SOURCE: 2006 toyota camry JBL radio; controls don't work
THIS IS A RADIO PROBLEM, THIS PROBLEM WILL REQUIRE THE RADIO BEING SENT OUT TO AN AUTHORIZED FACTORY ELECTRONICS REPAIR CENTER, THERE IS NO BLOWN FUSE OR THE RADIO WOULD NOT EVEN TURN ON.
SOURCE: radio works on tech bench, not in the boat
Yes, the yellow wire is the switched hot lead - it is typically connected in one way or another to the ignition switch. There is also a smaller gauge red wire that is connected directly to the battery (through a fuse of course). Both of these wires have to have power for the radio to work. Also the black wire has to be connected to a good ground. If all three of these wires are confirmed to be in good order (power where there should be power, ground where there should be ground and no shorts) the radio should at least power up when they are all hooked up and the ignition is on.
SOURCE: I am trying to find
You will find the maual you need by using the following link :
http://www.prospecelectronics.com/JBL%20MR6%20manual.pdf
SOURCE: Jbl Marine Audio Wired Remote - my screen is
Will a REM 25 remote work with the MR 15 JBL radio?
SOURCE: We suddenly have lost sound from our radio. All
possibly the speaker harness in back of the radio came loose, and fell out. remove the radio, and check the wiring harnesses.
Hope this helps
