Question about Tomtom GPS
Tom tom screen calibration for 9.510 Nav Core version
Does anybody know the method, how to calibrate screen for Tom Tom Go730 with 9.510 Nav Core version installed? Would be glad for any suggestions. Thanks.
    Sergeant:
    Champion:
  • Tomtom Expert
  • 373 Answers
Cant be done, if the touchpad is out of synch it needs to be replaced.
Posted on Dec 29, 2014
SOURCE:
ctf1800
  • 4402 Answers
SOURCE: tom tom go 510 Sat Nav
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your
computer True True (``````````` (``````````` 0 95250 95250 clip_image002.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup True True (``````````` (``````````` 0 95250 95250 clip_image002.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Posted on Jan 25, 2008
  • 39 Answers
SOURCE: When I bought my sat nav Tom Tom version 3 it
move the receiver to a different part of ther car if your car's windscreen is coated windscreen
Posted on Apr 20, 2009
  • 26 Answers
SOURCE: My C-330 is stuck on the map update screen.
did you try to reset the device?
Posted on Jun 17, 2009
SOURCE: Re-calibrate Screen on Tom Tom One Regional
I tried this to fix my tomtom one, but it didn't work.
It may be worth a try on other models, though....
http://www.yournav.com/forum/index.php?showtopic=12622
Posted on Aug 07, 2009
leethedeuce
  • 4472 Answers
SOURCE: I have a is Tom Tom Sat Nav no manual
http://safemanuals.com/user-guide-instructions-owner-manual/TOMTOM/GO%20300-_E
You can download the manual for the GO 300 from the above link. If your unit is different from the one you have listed above please let me know and I can give you the appropriate link.
Thank you,
Lee
Posted on Aug 18, 2009
How do I calibrate my Tom Tom?
The touchpad can not be re-calibrated.
It needs to be replaced.
compu-sat.co.uk
Feb 23, 2014 | Tomtom ONE GPS Receiver
Touch screen on tom tom one is out of alignment toward the top. bottom part of screen is ok.
I found this on the internet, hope it helps....
Touch screen Calibration.
Method valid for NavCore versions until 8.051.
A manual method to correct the calibration of the touchscreen input device of any all-in-one TomTom systems consists in creating a file called calib.txt (e.g., with notepad) and saving it in the main directory of the TomTom disk memory (e.g., the SD card; the same directory of the ttsystem file).
calib.txt should include one line with four numbers separated by a space: MaxX MinX MinY MaxY
Notice that the ‘x’ sequence (max, min) is inverted than the ‘y’ sequence (min, max). MaxX > MinX and MinY < MaxY.
For instance, the file can include:
928 118 107 912
Each TomTom device has its own most appropriate sequence.
In order to compile the file with default data, one method could be to perform a TomTom reset (or to eject the SD card), powering on the device and holding down the ON button for a few seconds until a unit status screen appears. The line named “Touchscreen calib. data:” will include four numbers that in sequence represent MinX MaxX MinY MaxY; these numbers can be used to fill the configuration line of calib.txt remembering to swap the first two ones. For example, if the unit status screen returns 118 928 107 912, calib.txt has to be saved with 928 118 107 912.
Tuning can then be done by adjusting these numbers until the touchscreen is calibrated. Distortions like screen rotation, trapezium and rhombus correction cannot be achieved with this method even if tuning these parameters can provide an acceptable touchscreen management even in presence of distortions; the best screen to tune the calibration is exploiting the soft keyboard of the NavCore application.
For instance, in my old TomTom GO Classic device I realized that, after activating the NavCore soft keyboard, when moving vertically (Y axis) the cursor appeared calibrated, while the horizontal movements (X axis) prevented to manage the left and right key columns (especially in the left bottom corner positions). So, I left the last two digits unaltered and, after some tests, I successfully used the following values: 805 200 107 912.
Method valid for NavCore versions post 8.051.
For NavCore versions 8.2x and 8.3x, use the same method as mentioned above, with these small differences:
the file should be named cal.txt (and not calib.txt) and should again be positioned in the main directory of the SD (or HD) drive of the TomTom system (e.g., the same directory where ttsystem can be found). Besides, the four numbers included in the file should have a different sequence than what previously described for versions until 8.51; cal.txt shall include the following sequence: MaxX MinX MaxY MinY (notice that also MaxY precedes MinY).
For instance, cal.txt could include the following four digits: 928 118 912 107
Again, these numbers are specific of each TomTom single unit.
E.g., my TomTom GO Classic correctly runs 840 245 912 107.
Feb 23, 2010 | Tomtom ONE GPS Receiver
My Tom Tom go won't click where I tap on the screen. It clicks an inch below where I tap it. Does anyone know why? I tried to reset it already a ton of times but I don't know what to do next and I can't...
Hello akwadsworth,
It sounds like you need to calibrate your screen. Go to the main menu and then preferences, on one of the menus in preferences should be an option to calibrate your screen. Follow the on screen instructions and you should be fine.
Post back if that does not work. Thank you for choosing Fixya!
Aug 29, 2009 | Tomtom GO 920 GPS Receiver
Touch pad seem to be out of calibration - when you touch anywhere on the screen, it highlights about 1/2 inch above where you are pointing - very hard to enter addresses etc.
not sure what tom tom you have but try this (found in a forum)
SAW THIS IN ANOTHER FORUM - RESOLUTION TO SCREEN CALIBRATION ISSUE
So I will give it a try to help sort out a friends TomTom.
928 118 107 912
May 19, 2009 | Tomtom ONE GPS Receiver
Screening problems!
The calibration for the screen has become misaligned. Unfortunatly tt does not have a program to correct this problem.
May 01, 2009 | GPS
Eclipse AVN2210p tom tom continuously restarts
What Navcore (application) version and map version do you have?
Mar 20, 2009 | Eclipse AVN2210p MK II CD Receiver w/...
Magicolor 2200DL
calibrating FW:412050G123D0 I think it says calibrating firmware. what happen before you get this error? did you try to wait for a long time?
Oct 05, 2008 | Minolta magicolor 2200 DeskLaser Printer
GPS Logo
202 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
