THE DVD PLAYER WILL ONLY SHOW "OPENING" BUT WON'T EJECT THE DVD.
SOURCE: Purchased a Bose Lifestyle 38 demonstration model and can't get it off demo mode now
Unplug the unit for 10 seconds. Plug it back in and repeatedly push the "eject button" until it displays "opening tray". Take out the disc and put in whatever you like.
SOURCE: Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
SOURCE: open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
SOURCE: bose dvd player door want open
You just unplug the cord form the wall for 4 hours, after 4 hours plug it again. The purposed of unplugging is to dissipitate the
stored current in the memory IC so it will gone.
Good luck:
Regards;
VOTIT
Don't forget to rate;
SOURCE: Bose Lifestyle 38 Unsupported Format message
All you have to do is carefully take the top off and clean the "Iris" which is the reader with a little alcohol and cotton swab. Bose will charge $165 plus shipping to do this. Go to website metacafe.com and search how to clean DVD players and it will show a video, easy to understand.
