If you want to see the date /time info while viewing the pictures on the camera, you can change the display settings, press the DISP button, till you see a smaller picture and the date and time on the bottom of the screen.
If you want the date and time printed on a picture, you should use the pict bridge option from the camera and in the setup you should chose the setting for that. See page 165 and following from the manual.
But the simple timestamps of the yellow or orange stamps like in the older digital cameras, won't work.
Because the camera keeps a all information stored in the EXEF part of the picture, it won't destroy the jpeg it produces. If you really want the date and time imprinted, you should use a program on the computer, to use the date and or time info and brand it in the picture, before saving it.
Be aware all pictures do have the date and time info in them and most viewers on the computer (whatever OS) will show the info when asked, anyway.
SOURCE: Putting the date/time stamp on my pictures
I have the same problem, if someone solved this, please let me know [email protected]
SOURCE: Setting date and time on the picture
OK, I FOUND SOME INFO ON A WEBSITE THAT I'M GOING TO HOTLINK FOR YOU. SEEMS LIKE THE ONLY WAY YOU CAN DATE/TIME STAMP A PHOTO IS TO HAVE THE CAMERA IN THE POSTCARD MODE. YOU CAN READ ABOUT THIS IN THE WEBSITE I'VE LINKED FOR YOU. HOPE THIS SOLVES YOUR QUESTION, AND IF YOU NEED MORE HELP, REPLY TO:ARCLIGHT1217. IF THIS HELPS, PLEASE REMEMBER TO RATE THIS SOLUTION. THANKS!
http://www.imaging-resource.com/PRODS/SD750/SD750A3.HTM
GOOD LUCK!
SOURCE: date stamp on -off setting in menu does not function
The date stamping option is only available when shooting in postcard mode.
SOURCE: removing date stamp off pictures arlready taken
Turning the date stamp off will only work for future pictures you take...The only way to remove the date on the pictures you have already taken is to do a crop or photshop the area...
SOURCE: date time stamp
The camera must be set in the Postcard mode under the resolution setting (L, M1, M2, M3, S, Postcard) on the function menu. Press Function, scroll down to bottom, then scroll to the Postcard mode and press the Set button.
Testimonial: "Fantastic! I've been trying to sort this out for ages, and that has done the trick! Cheers :) "
