What are you sending to the projector? The ES4 is a native S-VGA resolution machine. This means it has a 4:3 display panel with a pixel count of 800x600. It will accept higher resolutions, but there may be some combinations that are 16:9/16:10 that the projector isn't happy with; specifically 1080p @ 24/50/60Hz. It maxes out at 1080i 60Hz. So if you are connecting a laptop with a native resolution of 1920x1080 then the projector will struggle.
The other thing you should do once you get a signal working on the projector is to set the laptop output to the projector's native resolution. This will give the crispest image.
Toggle the laptop display (Fn + appropriate F key) so that laptop screen is off and the projector is the only thing getting a signal. Then right click on the Windows desktop area, and then select Graphics Properties from the sub menu. Change the settings from there..
