Won't charge. charger power is on, but charge light never comes on and it doesn't charge
The batteries may be too discharged for your charger to operate correctly. Use a 12 volt battery charger without automatic charging function and use it to charge the batteries individually not connected together. It might take 2 or more days to do it , before the original battery charger will work normally. There's a chance the batteries are damaged and won't charge at all.
it sounds like dead cel in one of the batteries, try having batteries loaded tested.
SOURCE: Dad has a jazzy select
VB the batteries are too weak for the chargers to pick up. Unfortunately you will have to puchase new batteries. Now since the facility was responsible for not keeping the batteries charged I would ask that they pay for the new ones. Good luck with that. The batteries you need are U1 batteries. If you have a battery warehouse type store near you they should have the batteries or an Interstate Battery outlet store. The batteries should be around $200.00 for two. Try not to get them at a local provider cause they'll charge you more. Hopes this Helps you
SOURCE: When I charge my Jazzy select 6 over night the off
I am assuming that the PWC runs and the batteries behave like there is a full charge. The performance of the Jazzy is good. If you have a volt meter you can check the voltage at the charging port but this is too difficult for the average user.
There is a battery display indicator (BDI) on the joystick that indicates battery charge through a series of LED lights. More lights, larger charge and higher voltage on the batteries. There are two reasons why the LEDs are not lit assuming the first two sentences are true:
1. The LEDs or the circuitry running them is burnt out.
2. The LED module has come unplugged from the circuitry.
The solution for both problems is the same. Open up the joystick case( if it is out of warranty )and inspect the LEDs and wiring. The easiest and most expensive way to solve the problem is to replace the joystick assembly. If you do nothing there is a good chance that you will get stuck somewhere because you do not know the charge state of the batteries. If it is under warranty your problems are solved. Call a qualified dealer in your area and have the problem component replaced.
Hope this helps.
SOURCE: I have a Jazzy 1113 powerchair and the on board
my chair jazzy 1113 ats won't move.all the lights are flashing and the batteries are fully charged why are they flasng
SOURCE: my jazzy was sitting for
I strongly suspect your batteries are dead. The unfortunate part is that the gel batteries used in power chairs will not usually take a charge after they are completely depleted. The only solution is to load test the batteries and replace BOTH of them even if only one tests bad. ( I think you'll find that both batteries are dead)
