Apple iPad (16 GB) WiFi Tablet PC Logo
A
Anonymous Posted on Sep 07, 2014
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
I have been using it for some time and I don't know what happened it just locked and started asking for password
robert_welsh
Level 2:
  • Expert 85 Answers
  • Posted on Sep 08, 2014
robert_welsh
Expert
Level 2:
Answers
85
Questions
Helped
13200
Points
138
Reset an iPad Synced with iTunes Step 1 Connect your iPad to the computer with the USB cable that came with your device.
Step 2 Launch iTunes if the application doesn't launch when you connect the iPad.
Related Reading: How to Put a BlackBerry 8520 Back to Factory Settings
Step 3 Remove the iPad from the computer if iTunes asks for your passcode, and then follow the steps in Section 2.
Step 4 Right-click on the iPad icon in the left column of the iTunes window if you're not prompted for the passcode. Click "Back Up."
Step 5 Click "Restore" when the backup finishes. The iPad will enter Recovery Mode and reset its settings.
Step 6 Right-click the iPad icon again when the device reboots and select "Restore from Backup..." This replaces the content that was deleted during the reset.
Reset an iPad Never Synced with iTunes Step 1 Disconnect the iPad from the computer, but leave the USB cable connected to the computer.
Step 2 Hold down the "Sleep/Wake" button for several seconds until a red slider appears. Move your finger across the slider to turn the iPad off.
Step 3 Connect the iPad to the computer while holding down the "Home" button to turn on the iPad.
Step 4 Release the "Home" button when you see a message that says, "Connect to iTunes."
Step 5 Launch iTunes. iTunes will alert you that it detects a device in Recovery Mode.
Step 6 Click "OK" and click "Restore" to reset the iPad.
Things Needed
  • USB cable
  • iTunes
Alma Robles Chiari
Level 1:
New Friend:
  • Contributor 13 Answers
Alma Robles Chiari
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
3713
Points
49
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
Michael Lei
Level 3:
An expert that gotĀ 10 achievements.
Master:
  • Apple Master 498 Answers
  • Posted on May 23, 2019
Michael Lei
Apple Master
Level 3:
Master:
Answers
498
Questions
0
Helped
121967
Points
1736
I think you have to restore your iPad. You can follow below content.
How to unlock iPad without password or how to unlock disabled iPad? It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Method Three: How to unlock a disabled iPad in recovery mode?
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
For more details, check: How to Unlock iPad without Passcode
computarman
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 11 Answers
  • Posted on Dec 25, 2016
computarman
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
11
Questions
0
Helped
6606
Points
31
I bought an IPad mini with a passcode and I tried many times to restore to factory and I always got errors like 3194, I believe. Restore failed on several Windows 7 laptops (by putting the iPad mini2 into recovery mode because the IPad mini2 would not go into DFU) that I have and I was finally able to restore to factory using a Windows 10 machine which is just crazy but nonetheless it worked.
2 Related Answers
Anonymous
  • 4961 Answers
  • Posted on Aug 19, 2012
SOURCE: how do I unlock a locked up ipad?
If you've got a locked up iPad app or otherwise misbehaving iPad, and want to reboot / reset your iPad, simply hold the sleep and home buttons together until the iPad restarts.
You'll see the shutoff slider come up first, but just keep holding. The screen will go blank and the Apple logo will reappear as the iPad reboots.
Note: this does not reset any data on your iPad. This is just a restart, equivalent to rebooting your computer.
Anonymous
  • 32 Answers
  • Posted on Aug 27, 2012
SOURCE: How do i reset my locked iPad?
if u r having software of that i pad u can use it with datacable and then format it
How do I unlock my ipad activation lock without i-tunes. I forgot my password and apple I'd.
If you bought a second-hand iPhone/iPad stuck on the activation lock screen and don't know the previously used Apple ID and password, iMyFone iBypasser can help you activate iPhone/iPad without Apple ID. This excellent tool came out in 2020 and has helped many users who reset their own iPads without logging out the previously used Apple ID.
2answers
How to unlock an ipad
If you remember the password of your iPad, it's would be easy. However, you can still refer to below steps to unlock an iPad without password.
iPad Air
iPad mini/iPad pro
restoring-ipad-software-cpmn0ithqpr5j0kd3fh1ly4i-5-0.png For more details, check: How to Unlock iPad
3answers
How do you unlock the Activation Lock on an ipad when you don't know required Apple id or Password
Your apple ID is normally your email and use the FORGOT PASSWORD line they will send a reset to your backup number or email address
2answers
I have a ipad ios 9.3.5 and its lock me on activation icloud pls help me to skip icloud activation lock
Hey! sorry but you will need to enter that appleID password to reactive the iPad. If you still have the original receipt you can call apple and have them start the recovery process.
I appear to have locked my ipad how do i unlock it lock off my ipad
if you remember the password then slide to unlock or else if u dont remember it you have to put it in to dfu mode and then restore it with itunes. make sure you have backed up your ipad.
2answers
I just bought a andriod tablet from someone and i dont know the pattern lock or the email account how do i unlock it?
if its legitimate and not stolen just ask the person you bought it from for password or reset to factory settings and put your own pattern lock and email on it
How can I login to my iPad when the passcode isn't working?
You have to reset your iPad. Just follow below steps.
iPad Air
iPad mini/iPad pro
itunes-summary-4wdcyutupah1kirb0sfrwsm2-1-0.png For more details, check: How to Unlock iPad without Passcode
My ipad is displaying a picture of a person behind bars as if in jail how do i unlock it from this screen? N
If it is your iPad, you must know the unlock code. and the password connected to your Apple id. If you entered three times a wrong code, the iPad locks up and only can be unlocked when you enter your password, belonging to the Apple account the iPad is connected to.
This security is so strong it is not hacked. The legal owner still can send messages to it. Perhaps he /she did send the picture?
If the iPad is really yours and you have the invoice, take both and your ID, to an Apple store and ask if they can help.
On my apple ipad mini model A1432 that I bought from a friend the passcode that I'm putting in is incorrect. How can I get a new passcode?
After you put in the wrong pass code 3 times, you only can unlock the iPad with the correct password, belonging to the Apple ID from what is only a part shown on the screen. If you don't have the passcode nor the password Apple assumes you are not the legal owner, and you can't use the iPad anymore. Just go back to your friend, ask him to unlock the screen, to wipe the content and reset the iPad to factory settings.
For that goto settings, general and scroll to the bottom line and press that. then the second line wipe everything. Again the login code is asked. but after that the iPad is empty.Your friend should also remove the iPad from his list of registered Apple equipment.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
