Tape loads ok but will not play or record, display shows Er01. Tape will function ok both fast forward and fast rewind. Please help.
SOURCE: loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Testimonial: "saved the deck - I was going to replace it! fast response too! Thanks"
SOURCE: I Have an LG EC970W VCR which displays
MY TV DISPLAYS NO SIGNAL WHEN I TRY TO CONNECT MY VCR TO IT WHATS HAPPENING
SOURCE: rewind or fast forward
Try cleaning the pinch roller. A cotton bud dipped in methylated spirits should work, you may need several. Play a tape through to clean off the methanol residue. Avoid touching any semionductors !
If this doesn't work, you've just a tired motor.
