Karcher 2500 PSI Pressure Washer Logo
A
Anonymous Posted on Sep 07, 2014
Why does my karcher powerwasher starts and dies after 2 minutes
Powerwasher dies after starting
Cliff J
Level 2:
Scholar:
New Friend:
  • Expert 90 Answers
  • Posted on Nov 07, 2014
Cliff J
Expert
Level 2:
Scholar:
New Friend:
Answers
90
Questions
0
Helped
46785
Points
123
Dirty carb , clean carb, install a fuel cut off valve ( or start using it if you already have one) when you are done washing, turn off the fuel valve and continue spraying water until the engine stops. That will empty the carburetor bowl and the carb will stay clean until you want to use it again.
1 Related Answer
Anonymous
  • 65 Answers
  • Posted on Aug 28, 2009
SOURCE: I need repair instructions to repair my KARCHER K
http://scripts.karcher.com/scripts2008/bta/document/BTA-59612160-EN.pdf
user manul and troubleshooting tips
I have a Honda powerwasher with a Briggs & Stratton Motor that won't start unless you use starting fluid then it dies again after the starting fluid evaporates
No fuel... carburetor float/needle valve is likely stuck shut. Clean carburetor bowl and use a fuel treatment such as Seafoam, per directions.
5helpful
2answers
POWER CRAFT BY Karcher bought Aldi on 31Mar 05.2100Watts 130 bar.
You did winterize the machine? Leaving water in a powerwasher will freeze and damage the pump. It's a common happening, because people don't think of it or are not told by the maker.
4helpful
Excel powerwasher with B/S motor. Will start and
Is your air filter dirty? If so replace it. If it is still doing the same thing try this:
Turn off the fuel valve, or drain the gas tank, then place a rag under the bowl to catch the gas that will run out (the bowl is under the carburetor). Loosen the "nut" that holds the bowl on, and after the gas has stopped draining remove the nut and bowl. Blow out with compressed air, if available. Put the bowl back on and try to start it. If it still will not run off choke, the carburetor probably needs a good soaking or to be replaced.
1helpful
I need repair instructions to repair my KARCHER K 378 Powerwasher
1helpful
2answers
My pressure washer works 4 a while then starts to sputter & dies?
I am going to suggest a tune of of the engine. Change the oil and oil filter. Check the air filter is clean and replace it if it isn't. A new spark plug.
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
1helpful
Karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Karcher power washernot as powerfull as previously
Look for +/- on knob and turn + direction for max pressure.
2answers
Honda 2750i Powerwasher
I had the same problem 3 years old, maybe used 10 times - removed the air filter and the washer started fine. The air filter looked fine - I have not tried to replace it or figure out the root cause. I was just happy to get it running again :)
Karcher pressure washer
I had same problem won't build pressure. go to http://www.wmpcs.com/index.php?main_page=page&id=14 and see diagram. I pulled white plastic cover off top of pump (2 torx screws), remove main pump from gas motor otherwise you wont be able to get at the valve below. The important part is the valve below the the white plastic piece, it has a raised slot and mine was stuck in there. I used needle nose pinched together with pliers to lift it straight up. After wd40 and cleaning the hole and valve it should pop in and out easy. Put everything back mine worked like a charm after that. So at least I know what the problem is. Great powerwasher-I use for house painting part time and love it.
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
