Our machine is notifying that it needs to be decalcified but there is no cleaning option in the menu.
You can descale with vinegar or a commercial descaler fluid or tablet to remove thelime.
There are product made for this:
http://www.walmart.com/search/search-ng.do?search_query=Coffee%20Maker%20Cleaner&adid=22222222224211445902&wmlspartner=wmtlabs&wl0=3535535214&wl1=e&wl2=coffee%20maker%20cleaner&wl3=15084042955&veh=sem
You'll notice the first one specifies it is for Automatic Drip Coffee and Espresso Machines
SOURCE: Decalcify?
I had the same problem with a Saeco Royal Digital. I ran the decalcifying liquid through the machine with the automatic descaling program as per the instructions on the bottle and the DECALCIFY message stayed up.
I solved it by going to the menu and selecting "Signal Descal." and toggling it from No to Yes. I escaped back to the menu and git the usual "Select Product".
Hope this helps.
to descale the machine there is a auto descale function on the machine using the double ellipse button. Hold down button for about 5 seconds display will read descale(prepare solution first). The rest is easy just follow the onscreen instructions.
SOURCE: Trevi Spidem Espresso Machine that leaks
remove the brew unit and look at the white valve behind it, below that valve there is a small chamber which is probably filled with coffee grounds and water, clean chamber and below chamber is a small discharge hole that leads into the draintray, make sure it is clear.
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Rinse 4 times at least after running thought the vinegar or descaling fluid
http://www.keurig.com/customer-service/b...
