SOURCE: The rear hatch on my 2003 Hyundai Santa Fe won't stay up.
Yes. Your Local Auto Parts Store should Carry these as Direct Replacements. If Not, Sears Carries them.
SOURCE: ''check engine light'' illuminated, 1004 Hyundai, Santa Fe
If you live in the US, take it to qany Auto Zone store and thy will read the codes off for you, I would suspect any right thinking competitor would do the same, check if you don't have one near by.
Hope this is of some help.
Ed
SOURCE: PROGRAM KEYFOB FOR HYUNDAI SANTA FE
This is from the factory service manual of your car:
There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote. Translation you need the dealer to do this.
SOURCE: Change serpentine belt 2004 Hyundai Santa Fe
it uses a spring loaded tensioner.use a breaker bar to rotate the tension and it should just come off.if u need a pic or anything else to do it let me know,
SOURCE: need fil for error code P2626 Hyundai Elantra GLS
P2626 O2 Sensor Pumping Current Trim Circuit/Open (Bank 1 Sensor 1)
I'll sure this has to do with a faulty O2 sensor. This sensor is usually
located around the header of your car, or down more on your exhaust.
Try disconnecting your battery for 30 mins, hook it back up, and start
your car again. This will erase the error. See if it comes in again.
Hope this help (remember rated this post).
