Computers & Internet Logo
A
Anonymous Posted on Sep 07, 2014
Lab top volume is showin up in left corner of screen
How can I remove the volume control from my lap top Toshiba with windows 8
MOUDY
Level 1:
  • Contributor 54 Answers
  • Posted on Sep 07, 2014
MOUDY
Contributor
Level 1:
Answers
54
Questions
Helped
5369
Points
92
By default that is how the icon displays
5 Related Answers
Anonymous
  • 1067 Answers
  • Posted on Jan 27, 2008
SOURCE: TOSHIBA LAP TOP A135-S4656 SCREEN WENT BLANK BLACK
over heated the video area in it will have to cheak video card inside or motherboard chips on it got to hot when u play games on labtops u must ua labtop cooler never set it on your bed
Anonymous
  • 3422 Answers
  • Posted on Feb 08, 2008
SOURCE: remove bios pass word
Use hiren boot software.
its a bootable software which u have to write on a cd and boot the pc using that cd
CLick HERE to download it
Goodluck,
Please don't forget to rate me as fixya..
frankzjm
Frank Zhang
  • 191 Answers
  • Posted on Jan 24, 2009
SOURCE: my toshiba lap top 120 has a white line trough the screen
you need check
1) make sure the line is stable or changeable there when you folding the LCD lid or touch lid somewhere. there is some temp disconnection if the line changes sometimes
2) check and make sure the LCD cable and the plug/socket at motherboard and back LCD panel, they are no dirty and disconnection
3) make sure the LCD panel hardware damage (replace one) if the lind is stable there, mostly should change the LCD panel.
Anonymous
  • Posted on Jan 28, 2009
SOURCE: problem withe acer extensa 5620z lap top
WHEN I OPEN MY LAPTOP, ACER EXTENSA 5620Z
THERE'S A MESSAGE OF BOOTH MGR IS MISSING,
PLEASE HELP
Anonymous
  • 6966 Answers
  • Posted on Feb 12, 2009
SOURCE: No sound from my Toshiba lap top 2405-S221
Hi and welcome to FixYa,
I seem to remember that this particular model/series has a 'Sound Volume Control Dial' between the indicator lights and the headphone jack. Perhaps it just needs to be adjusted/turned. Of course the you could also verify that the soft controls (Volume Control and Wave) are set to your desired level and not muted. To check, double click on the speaker icon.
Pls post back updates on any developments. Good luck and thank you for using FixYa.
How to restore the volume to higher levels, when accessing news videos, Youtube, Skype etc? Levels are quite normal if I use my Media players for music. .
To change the volume using the Volume Control icon, you just need to do the following:
  1. Click the Volume Control icon in the bottom right corner.
  2. Now you'll see a new window that allows you to adjust your volume. Simply click the volume bar to set your volume to a desired level.
Nov 15, 2018
Reference; https://windowsreport.com/adjust-volume-levels-windows-8/
2answers
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Toshiba Satellite L355D-S7815 had windows 8, opened up laptop and cleaned all the dust out and now when i turn the laptop on it shows the Toshiba screen but no F2 or F12 option's.
What you are talking about is called no POST. You either shocked the cmos and the bios wont load or something is not hooked up right.
Volume control won't go away. Windows 8
right click on it, click settings and turn off start automatically. then right click on it again and click close.. Its a service that comes with the software, there are other ways to disable it but that's the simplistic one..
2answers
Hello my toshiba satellite c650 lap top turns on and then the screen goes black with a - on the top left hand corner and cant do anything so i wait and nothing happens how do i fix it
I cant help you resolve your problem but i have the same problem with my Toshiba but when the screen goes black i get a high pitched buzzing and i cant do anything but turn it off. I was replying because if you got a solution to why yours was doing this would be great if you could help me out..Thanks Tanya x
My HPPavalion Lap Top-Windows Vista Home-the screen is not showin
Tell your computer engineer to examine the connectors.
Did it fall on the ground?
Speaker problem
hi im josh!may i help you? seldom you can find keyboards having audio controllers. you can adjust the volume through the icon a small circle or small speaker button near the time bar right lower corner of the screen.or you can go to start buttons, then run then type dxdiag. upon viewing the diaglog box.you select audio controllers then try to adjust the volume. and this could be done if you are using windows xp. Good luck!
2answers
You may want to go to the "Device Manager" or Sound Devices, find trouble shoot...or some other tab...roll back driver, it may be a bad version of your sound driver
Red Padlock displayed in top left corner of a blue screen.
try this with the tv off simultaneously press and hold volume minus on the tv's front panel and clear on the remote control for 5 seconds then enter a new password good luck
shaun
Mcafee security centre is a blank screen
Remove IE 8 Beta. McAfee has trouble with it.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
