The system board should be labelled where the jumper pins connect. if you are in the right spot, but the lights dont work, then flip the connection around, because LED lights are polarized, meaning they will not light up unless the + and - are plugged in correctly. Usually, the wire with the COLORING on it is the + and the white, gray, or black wire is the -
