Automotive Bully Tb-203 Clear Lens Led Third Brake Light Logo
A
Anonymous Posted on Sep 07, 2014
1997 honda civic Car is off. brake light wont shut off.
I already bought the brake light switch. I need to know which fuse is for the brake light so that I can take it out and install the new brake light switch
Gary Hill
Level 2:
Sergeant:
  • Expert 462 Answers
  • Posted on Sep 07, 2014
Gary Hill
Expert
Level 2:
Sergeant:
Answers
462
Questions
Helped
129420
Points
926
If you cant find the fuse just disconnect battery cable
I have a 1997 Honda Civic 4 door my dash lights are out and the dinging to my headlights is not coming on and I checked every light bulb and every fuse I don't know what to . Is is the dimmer switch
HONDA ILLUMINATION NOT WORKING * HOW TO FIX ...
? 3:24
https://www.youtube.com/watch?v=oOHwDWjmYWU
Feb 28, 2011 - Uploaded by vehix411
No lights,cant see the dash lights,bad bulb,how to change bulb clucter ... i have a 2001 honda civic i installed a new radio andmy cluster lights are ... I just bought the computer or (multiplexer whatever) for my 1997 accord because my back tail lights won't turn on but I ... Martin Nikolov 4 months ago (edited).
Removing a Honda Civic instrument cluster - YouTube
? 4:01
https://www.youtube.com/watch?v=kzp1VqdlmU0
Oct 28, 2012 - Uploaded by mike937739
George L 4 months ago ... I used it to fix my burnt out check engine light bulb in my 97 civic. ... I have no light on my dashboard I already replaced the fuse but still nothing? so I'm ....2005 Civic cluster in 1997 Civic working!
1997 Honda Civic Instrument Panel Lights Problem ...
? 1:26
https://www.youtube.com/watch?v=mYVt93Rao6g
Mar 26, 2013 - Uploaded by fockyoumang
1helpful
Why wont my 93 honda civic ex start and run and come out of park
You have to have power to the brake switch and the key switch to release the park solenoid.
There is an 80amp fuse and a 50amp fuse that powers the key switch.
Have you checked them to see if they have power ?
2helpful
2answers
My clutch won't engage 1997 Honda civic
Clutch plate and pressure plate seem to be too weak to pull the car. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
5helpful
2answers
My 2001 honda civic brake lights won't turn off after the car is shut off. I can I turn them off so my battery will not die???
You can pull the brake fuse (See owners manual). Sounds like your brake light switch is out of adjustment, or bad. (Located on the upper part of the brake pedal arm)
1helpful
My car is off but my brake lights are still on how can I shut it off??
remove fuse for brake lights, lights staying on is caused by bad brake light switch, which is under the steering column on the brake pedal, remove switch replace with new switch, re-install fuse for brake lights
My tail lights wont shut off...it drained my battery the other day :(
Unplg the brake light switch under the dash or pull the brake light fuse. Brake light Switch is probably worn out and needs to be adjusted or replaced
2answers
I have a 1990 honda civic ,and the tail lights stay on ,but the brake lights dont work
check the bulbs first, then the fuse, then the brake light switch
Brake lights/horn fuse keeps blowing
go after the relays. they are powering the horn and yor brake lights
19helpful
3answers
Car brake lights won t turn off when car is shut down 1996 Honda Odyssey
It should be your brake light switch. There is a little plate welded to the arm of the pedal that has a hole with a rubber stopper. The rubber stopper is most likely missing, or damaged. You should be able to take a flashlight and see the plate and the switch. If the hole is plugged up, you will need the brake light switch, if not, replace the plug.
Top Pilot Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Pilot Vehicle Part and Accessory Expert? Answer questions, earn points and help others
