Perpetual datejust
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
Unscrew the crown pull out the crown to the first position, One click and rotate the crown clockwise. This is for Quick Set models
For non quickset
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
SOURCE: Can you please tell me how to set my Rolex Oyster
24 hours passes and the day and date do not change. Does it need service? Have I broken something? I can pull the crown out 2 notches and change it manually----but it doesn't operate automatically. thanks [email protected]
SOURCE: If the watch is not worn for a day, is it normal
mcdevito75 here, Yes it is normal, especially if your Rolex is an automatic watch. The motion of your Wrist / Hand keeps your watch wound thru the Counter balance on the movement, as the counter balance turns it winds the mainspring little by little, thus keeping your watch wound. Once you take off your watch, if long enough the mainspring simply un-winds and slows and will eventually stop your watch completely. You can keep your Rolex wound even when you take it off by means of a watch winder, a small machine that will keep your watch in motion, or by hand, by rocking the watch back and firth in your hand for about 30 seconds, say before you gpo to bed at night, this way there is always some wind to your watch.
SOURCE: I have a ladies rolex
I suggest you talk to Rolex or thier local dealer to see if the slowness you are concerned about is outside the guaranteed accuracy for the watch.
I can't find any reference to accuracy on the Rolex site but other makers have mentioned 15 seconds per month for the accuracy of an automatic watch. This seems poor compared to the accuracy that we have become used to from electronic watches but it is a mechanical watch!
Speaking to the maker might clarify what you can expect from your watch and if it is outside their tolerances, I would expect them to put it right under their warranty.
