SOURCE: manual for nostalgics ice-cream maker
I found the manual able to be downloaded on multiple sites. Go to Google, type in the words old fashioned ice cream maker, and in the returns you will find links to web addresses that have these manuals available for downloading using Adobe. The original manuals in both English and Spanish. I didn't save the webaddresses, but I can assure you that they are there on Google. Don't type in Nostalgic Electrics Old Fashioned Ice Cream Server, just old fashioned ice cream server, and then go to the web address, it's the one that states they have the manuals for all ice cream makers, and type in the ICM-507 product designation or just click the available picture of the ICM-507. I will try and recover that web address and post it here. Found it! Here it is: www.pickyourown.org/icecreammakermanuals.htm I can assure you it is there! if you want the whole enchalada: www.pickyourown.org/icecream/Nostalgia%20%old%fashioned%20%soft%20serve%20ice%20cream%20maker%20manual%20ICM-562.pdf. And thats the real "skinny" for this model folks! Whew, you'll have carpal tunnell time you put all that in there. Kindest regards, Joe R. Downs Jr.
SOURCE: ICE-20 Frozen Yogurt/Ice Cream maker
Here is the link to the manual:
http://www.cuisinart.com/share/man/82_man.pdf
-Tha Mp3 Doctor
SOURCE: need new blade from Il Gelataio ice cream machine
Call this # for all Simac parts. 1800 223 1898
SOURCE: Ice cream machine was making ice cream and now the
a.improper pressure switch setting . b. low refrigerant level. c. TQC needs adjusting. d. faulty solenoid. e.insufficient mix in freezing cylinder.
SOURCE: need repair manual for IL Gelataio 1600 ice cream
Had same thing. Try turning timer a bit. Sounds silly, but may fix. I took off cover (4 screws, two on each side, cover lifts straight up, then tilt back) tapped capacitor, pulled leads, reattached leads, removed motor (elco mg, attached with three screws) etc. Turned blades with motor out, started motor unattached to "transmission", put everything back together and voila! I think the timer was the issue.
