Optics Logo
A
Anonymous Posted on Sep 06, 2014
Ballistic drop chart
Nosler 140 grain bullet loaded with 47 grains of IMR 4064
JBnID
Level 2:
Champion:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 243 Answers
  • Posted on Oct 08, 2014
JBnID
Expert
Level 2:
Champion:
Cheetah:
Answers
243
Questions
0
Helped
36705
Points
281
What caliber? What velocity?
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Mar 01, 2009
SOURCE: muzzeloader won't fire ,new nipple,caps fire,nothing is pluggedl.
its not a bullet problem you can shoot that out of your hawken muzzeloader your problim is getting the pan powder to ignight your powder in the barrel you need to make shure powder never got damp now on your hawken you have a removable torch hole were the pan powder lays take that out and just drill the hole out bigger not much just a little bigger in the part you took out this will make your hawken fire without any problem i have done this to many hawken rifles and its like night and day how it fires hope this helped ya out and good luck
Anonymous
  • 103 Answers
  • Posted on Aug 28, 2009
SOURCE: Rifle is shooting
The reason your shots are stringing is because the barrel is touching the stock probably at the end of the forearm. As the barrel heats up, the problem gets worse. Try sanding out the barrel channel and free-floating the barrel all the way to the recoil lug. Next, torque the action in the stock the recommended amount with an inch pound torque wrench. I torque my Remington 700 at 45 inch pounds for the front screw and 35 inch pounds for the rear screw. If you have a plastic trigger guard, 35 inch pounds will be too much for the light plastic trigger guard.
agent91
Ned White
  • 2100 Answers
  • Posted on May 04, 2010
SOURCE: How to use the BDC on my rifle scope
  1. Step 1 Take a rifle with a properly installed BDC bullet drop compensating reticle to a rifle range. Using ear protection zero the scope reticle so that the point of impact corresponds to the center of the cross hairs at the distance you have selected - typically 100 or 200 yds.
  2. Step 2 Determine the trajectory of the specific cartridge you have selected. There are several ways to do this. Ammo manufacturers publish trajectory and wind drift information. There are web based ballistic calculators like http://www.biggameinfo.com/BalCalc.aspx which will tell you how much your bullet drops at known distances.
  3. Step 3 Scope manufacturers like Leupold can be a valuable source of information about their reticle: "Leupold® Ballistic Aiming System: Boone and Crockett Club® Big Game Reticle aiming system provides a series of additional aiming points to improve your ability to shoot accurately at longer ranges. Nikon2_bing.gif also provides good information suggesting the marks on their reticle be used for zero at 100yds followed by circles below representing 200, 300, 400 and 500 yds if the cartridge travels around 2800 ft per sec. Nikon suggests the center cross hair be zeroed at 200 yds for magnum calibers traveling around 3000 ft per sec. We understant that each variation of different bullet weight and powder charge changes trajectory and a scope manufacturer can not build a different reticle for each different cartridge made so practice on the range to determine how well the marks relate to the actual impact of where your bullet strikes at a know distance is important. The one thing that people using BDC scopes typically have problems with is that a BDC scope has the reticle in the second focal plane of the scope. If the reticle was in the first focal plane of the scope the reticle would look smaller on low powers like 3x and grow proportionately larger as the power increased to say 9x top power. The problem is that while the marks on the BDC reticle correspond accurately to the bullet drop at the know distances 200, 300yds etc. What happens when you lower the power from the scopes maximum power to any other lower power is the reticle stays the same size and the field of view within the scope increases which means that the distance between these marks on the BDC reticle no longer corresponds to the point where the bullet will strike. In short BDC reticles only work at the maximum power of the scope or at a set specific power. At all other powers these BDC reticles do not accurately represent where the bullet will strike.
  4. Step 4 The center X always remains the same. If you zero at 100 yards and you know that your bullet drops 8 inches at 300 yards you could forget about the BDC marks and hold the center X 8 inches high - that works at any power 3x or 9x and should be used at lower powers. If you zero the center crosshair at 100yds and have the BDC scope at the maximum power 9X then the first line or circle below the center X should be the mark you place on the center of the 200 yard target----- the bullet strike should hit the center. If by some chance you put the scope on 3x and placed that first mark below the center cross hair on that 200 yard target you would shoot over the top of the target. This is because as the power of the scope decreases the field of view increases the angle increase and gets wider. You can experiment with known power settings and see at a specific power say 3x what that first circle down corresponds to and make notes because at any set power what the marks correspond to will be repeatable.
I got this from a website, hope it helps.
Leonard Zook
  • 243 Answers
  • Posted on May 31, 2010
SOURCE: HI I need to adjust my Karl Kahles Wein 3-12 x56
Here is an excellent article on zeroing scopes:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
Anonymous
  • 2702 Answers
  • Posted on Aug 28, 2010
SOURCE: I got in a tight spot needing a scope last season.
well one day you may lurn that cheap is cheap! and tasco is rubbish cheap! i would say without dought the cross hair in the scope has shaken apart,,,due to recoil,,,a 30-06 has a big recoil
try holding the rifle stock on your jaw and firing the rifle off?
when or if,, you wake up in hospital with a shaterd jaw and with no teeth left in it you will know then! and cheap tasco scope is an air rifle scope it cant take 2500ft/lbs of recoil???
so it wont take much of a kick to mess it up,,
i put one on a 303 enfield??? i got 3 shots before it fell to bits!
if your going to buy cheap scope's go for nicon gold crown?
Loading .257 Roberts using ww super +p primed cases with IMR 4895. Minimumum and max load data please. Looking at using 39.5 grains.
Can't say without knowing the weight of the bullet.
You can see data for many calibers listed at the Hodgdon web site.
Go to http://www.hodgdonreloading.com/
Jul 13, 2018 • Firearms
What would you recommend for the most accurate load for a 6.5x55 swed 96 mauser using a 140 grain bullet
48 grains. That round is hard to reload. You are probably out of spec for chamber clearance.
Apr 20, 2017 • The Optics
2answers
How much bullet drop with a 130 gr bullet out of a 270 at 1500 yds
Are you sure of your distance - that is 4500 feet, or .85 miles. Here is the drop up to 500 feet:
270 Win Ballistics Chart Coefficient GunData org
Firing 130 grain bullets at between 3250fps and 3300fps, the .270 WSM is capable of delivering high shock for impressively fast killing out to ranges of around 300 yards along with clean but sometimes slightly delayed killing out to 400 yards. After approximately 500 yards, wound channels become proportionate to the expanded bullet.
270 Winchester Short Magnum
Jun 02, 2015 • Optics
How much powder do I put in a 35 Winchester using IMR3031 powder with a 250 grain lead
http://www.loaddata.com/members/search_detail.cfm?MetallicID=3228
3answers
223 bullet drop chart
The best way to generate that chart is by shooting over a chrono and inputting the data into an external ballistics calculator, such as this one by Hornady:
Ballistics Calculator
It takes some work to gather the data, but it's much more accurate than any generic chart can be. I've used cards generated by a couple of different online calculators and have gotten better than acceptable results out of them with both my match barrelled 5.56 AR carbine and 7.61x51 Savage 10FCP. Good enough to ring 6" steels at 300 yards and 500 yards, respectively.
There are many other web-based calculators that can do the job, just search for "external ballistics calculator" for more.
May 26, 2014 • Optics
1helpful
Winchester powder load data
Going by the Lee reloading manual, IMR 7828 is not an option for a 150 grain bullet. That powder does not come up in the load data until using a 195 grain bullet. Most powder manufacturers have extensive load data on their website. I would recommend looking there.
Top Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an Optic Expert? Answer questions, earn points and help others
