Home Security Logo
A
Anonymous Posted on Sep 06, 2014
Device Management is missing, do I need to re-install program?
Model # xc36a
My laptop does not complete the whole screen, the screen is half, i have installed drivers but it has persisted
About Graphics and Video Card Drivers: Graphics and video Card Drivers serve as an interpreter between your Windows operating system and the Graphics and Video Card. In other words, these Drivers allow Windows to communicate with the Graphics and Video Card installed on your computer.
Most of the Graphics and Video Card Driver errors occur when the required Driver is missing, corrupt, or outdated.
Common Graphics and Video Card Driver problems: In case of a Graphics and Video Card Driver related error, your operating system will not be able to access or make best use of the functionality of your graphics or video card.
Below are the four most common Driver error codes and their meaning:
Error 1 - Reinstall the drivers for this device. (Code 18)
Meaning - The required driver is configured incorrectly or outdated.
Error 2 - This device is not configured correctly. (Code 1)
Meaning - The required driver is configured incorrectly or is missing.
Error 3 - The drivers for this device are not installed. (Code 28)
Meaning - The required driver is not installed on your computer.
Error 4 - This device cannot start. (Code 10)
Meaning - Usually, this error means that the required driver is outdated.
How do I fix Graphics and Video Card Driver problems?
Roll back to the previously installed Driver
Device Manager, an inbuilt utility in Windows, allows you to troubleshoot common driver-related errors. For instance, you may sometimes start experiencing driver related problems after you have updated it. To resolve the issue, you can roll back to a previously installed driver. To do this in Windows 7/Vista, perform the following steps:
  1. - Open the Control Panel window and double-click Device Manager
  2. - Double-click Display Adapters to view all devices under it
  3. - Double-click the device that is causing the problem
  4. - Click the Driver tab
  5. - Click the Roll Back Driver button and follow the onscreen instructions
Scan your computer using a Driver Update Tool
While Windows does provide an interface through which users can fix driver-related errors, the fact is that all driver-related issues cannot be resolved efficiently via Device Manager. Another fact is that resolving driver issues manually is a tedious affair. Also, you need to be proficient with Windows to carry out such a task.
On the other hand, driver management tools present no such problems. With just a click of the mouse, a driver management program scans your entire computer, identifies all installed hardware devices, and updates drivers for the identified devices
2answers
Missing drivers
Hi what make,model laptop? what drivers are missing? go to
www.drivermax.com, and download and install,run the program and it will search for and recommend the correct drivers for your system.
My acer aspire one webcam isnt working.everytime i click view my cam it displays-the webcam is not supported.sorry no webcam was found in your device...i tried to fix it in the control panel under device...
Suggest this problem may be resolved by restoring the webcam's drivers
The acer aspire one has a hidden partition with installation files to restore
1. the operating system to its factory default
2. applications (selectable)
3. drivers (selectable)
In windows
1. click on start at bottom left of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. click on Acer eRecovery Management
4. click on Reinstall applications/drivers
5. go to the row for the webcam and click the install icon on the right
Hello
The devices should function only requires installing the program softwares that are missing. Observe the device cameras brands models to acquire soafware programs on the internet to make computer capture communcations. Once the device codes have been installed, a camera sofatware make possible capturing picture from the device.
Feb 08, 2011 • IBM Webcam
Driver needs to update
1. If your laptop has internet access, use Device Doctor to scan and locate any missing drivers. Device doctor will provide a download link to any missing drivers.
2. If you have no internet access, you will need to goto your laptop manufacturer's website and search for drivers for your specific model of laptop (model number is usually located on the bottom of the laptop).
3. Be wary of other driver scanner programs, the vast majority are malware/spyware. Device Doctor is a program I use everyday at work.
Missing Acer eRecovery Management icon where do I go to download the latest version or if it is located on the pqservice(z) drive how can I install the software?
Hi. This software is currently not available for download. You may check if it is still installed in your notebook.
To launch Acer eRecovery Management:
• Click Start > All Programs > Acer Empowering Technology > Acer eRecovery
Management.
To read more, click this.
Do I need a driver for my LG GP08, and where can I get one for widows 7?
The way to check if your missing drivers is to go to your control panel the administrator tools the computer management the device management.
If you see any yellow question marks against your hardware then your missing drivers.
LG should have the drivers on their website enter your model number in their sight
http://www.bioticaindia.com/gp08.html
2answers
Why when I hibernate my toshiba laptop, I continually get the blue screen when I turn back on
A memory issue most probably. Make sure that your hard drive has enough space as well!
1helpful
2answers
Driver missing
We had the same exact problem but with a Compaq Pesario V6000 series notebook. Ours had to do with the NVidia System Management Controller but was listed in the device manager as a coprocessor. Kind of a bland description.
Solution: Downloaded and installed NVidia System Management Controller from here. Hope this helps.
I had already install but there is some exclamation remain in computer management like ? PCI device and ? sm bus controller
This is what we are here for: to help you. Now I will need some info. in order that we can make a duplication of your problem: Name of computer, Model number, MB ID and your story of what happened in detail, the more the better. To get the MB ID you have to play a little detective because it is hidden in between the white PCI sockets. The letters are so profound that you cannot miss it. If per chance they move the place, look at the upper right corner, around the RAM memory sockets. Thank you for considering our service...
My name is Constantin (arzconst is my nickname with "Fixya.com")
Top X-10 Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a X-10 Home Security Expert? Answer questions, earn points and help others
