How do I get a manual for this model TV
The 2014 model: http://download.oncorpus.com/UM%20LED32B30RQD%20-2014.pdf
The 2012 model: http://download.oncorpus.com/UM%20LED32B30RQD%20(2012).pdf
SOURCE: RCA TV Console
The oldest manual on the RCA website os for a CTC169. Since this set was manufactured in the late 70's early 80's the possibility of a bad CRT is there. Also you might have capacitors in the power supply that are failing as they are starting to dry up. With the change over to digital Feb. 17th 2009 comming up fast, you might consider trashing the set since it doesn't have a digital tuner. One might think it does as most sets from that era said "digital tuning" on the front.
SOURCE: I need set up help
this is the only mauual that comes up with 2057 follow this link. I hope this helps you. http://tv.rca.com/RCATV/RL/32F531TIB.pdf
SOURCE: need code for "20" Haier tv model tn201auv for rca guide plus+gem
Hi again,
It would seem that you posted multiple times.
For the manual of an RCA CRK76TA1 remote control, pls click here. It is a pdf file and would require Adobe Acrobat reader.
Offhandamnot sure if an RCA remote would work with a Haier television. Youcouldof course still try: 140 191 0000 10748 0001 002 003 004 005 006085 086223 323 2000.
Just a start, do postback how thingsturned up or should you need additional information. Good luck andThank you for using FixYa.
SOURCE: need manual for rca model 20632
I found a location online and downloaded the manual.
Thank you checking back
SOURCE: Need user manual for RCA R21GG8RA TV
Send a search request to http://manualfox.com - they will get it for you. Note: service is not for free, but worthy.
Need a SERVICE MANUAL not user manual
