Vizio VO47L 47 in. LCD TV Logo
A
Anonymous Posted on Sep 06, 2014
Vizio tv and charter cable. When I change channels the sound goes off then back on
5 Related Answers
Anonymous
  • Posted on Aug 30, 2008
SOURCE: Vizio Sound Problem
I've seen the same problem, went thought a couple of cable boxes. Turned out to be an AC line problem. Try plugging the TV into a different out, maybe in another part of the house.
Anonymous
  • Posted on Dec 24, 2008
SOURCE: Vizio 42" LCD HDTV - sound went out
Same thing just happened to me contacted Vizio had me unplug the TV from the wall for about a minute and then replug and cut the TV back on and everything was fine. I have the television hooked into HDMI1.
Anonymous
  • 10 Answers
  • Posted on May 23, 2009
SOURCE: VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
JT92677
Jeff Towle
  • 14 Answers
  • Posted on Feb 04, 2010
SOURCE: I have a VIZIO LED/LCD VF551XVT hooked up to a
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Anonymous
  • Posted on May 01, 2010
SOURCE: no sound after I change the channel. If I turn the
There is an incompatibility between Fios and Vizio audio. To fix the problem, on the Fios box, press "Power" then "Select" then "Menu", one right after the other. This accesses a secret menu on the Fios box. Using the arrow keys on the front of your Fios box, arrow down to "Additional HDMI Settings" then press the right arrow. Another menu will appear (may take a few seconds). Arrow down to "Audio Out" and press the right arrow to change from "Auto" to "L-PCM". Press the Power button to exit the menu. This should solve your problem. Thanks to Vizio tech support for the answer.
When I change channels, some times, the sound goes off. The sound comes back only after switching the cable box off, then on again. Is there a solution?
power off all units then redo all connections especially if it is HDMI they can be just a little lose and cause the sound to drop out
32in Vizio getting no channels
You have to go to your menu screen and change the settings from antenna to cable that should take care of it, and should be able to do a auto scan to load channel memory
My Vizio Bluetooth remote with keyboard has stopped working. I have spoken with Vizio tech supp. to no avail. I have a remote I used with my old TV issued by Charter because I have Charter cable. I want...
you need to contact charter for support on their remote and how to reprogram it for your new tv. for most universal remotes there is setup key or you have use a key combo to press to enter into setup mode and a user's for the cable box may have this info. however, if you do not have or did not get a user's guide then you need to contact your charter cable company for the info needed to get the 2 devices working together. refer to cable co. tech support.
We recently purchased a vizio 47 in lcd tv. sound goes out , returned that tv, now the replacement is doing the exact same thing. we have a great picture, just no sound. if we change the channel we get...
The cable box have problems,tries replacing the incomming broadcasting connecting wires,that goes to the tv Tuner signal board.If u still have the same problems,call ur cable company for a cable box replacement.
1helpful
Charter remote will not change channels--I have put in tv code but still nothing--noting on the remote will work except to power the tv on
You will need to program it to your cable box to change channels. Remember, the channels in your tv are coming from your box, so if the remote can't control the box, you won't be able to change channels. Call charter for help on programming remote to cable box.
4helpful
3answers
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
57helpful
13answers
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
