Computers & Internet Logo
mayur bhosale Posted on Sep 06, 2014
Hello. I have dell inspiron 5520 with Windows. 8 my problem is my laptop did't start & on the start screen dell logo apear but affter that screen only black screen. Blink please help me please thanks. In advance
Malav Desai
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Sep 07, 2014
Malav Desai
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
Helped
268
Points
16
Try Automatic Restore to the Last well know configuration date or else u need to format the pc and again install the os
5 Related Answers
Anonymous
  • 117 Answers
  • Posted on Nov 07, 2007
SOURCE: Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Anonymous
  • 3 Answers
  • Posted on Feb 24, 2009
SOURCE: ACER Aspire One screen black out after start up.
OK, Not sure about the Aspire One, But I had the same problem with the Aspire 5610Z.
I simply found the Bios battery and with a small screw driver, created a short circuit of the bios by touching the two leads (just for a couple seconds) from the Bios Battery to the Motherboard. And It Works Fine Now!
Be sure to Disconnect all power from the laptop, and remove the Battery before doing this.
You can do as I did and download a free manual of your laptop which shows you where the bios battery is located.
Good Luck ô¿ô
Anonymous
  • 52 Answers
  • Posted on Jun 10, 2009
SOURCE: dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Anonymous
  • 27 Answers
  • Posted on Aug 08, 2009
SOURCE: dell inspiron 640m...laptop screen in back. it
Possible only 2 solutions 1,the inverter has gone out and the othere is a replacement screen!
Anonymous
  • 1752 Answers
  • Posted on Oct 31, 2009
SOURCE: Dell Inspiron 1501 laptop with AMD 64 processor: Black Screen
Go to Control Panel/Power Options and check the settings. It's probably set to shut off after a period of time.
LAPTOP STOP AFTER WHEN WINDOWS LOGO APEAR
Stops? Powers off? Can you explain what happens in detail? Unplug, remove battery, plug in, boot, what happens, Windows Logo appears, then what?
Black Screen in start up evern in Safe Mode a black screen apears! Dell Inspiron 1525. OS-Windows Xp
This error means that the OS need to re reinstalled............ Use the following link to reinstall the OS and the drivers very easily
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
2answers
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
The pc starts and the Dell logo comes up but no windows boot
press the Fn Key and the power button see if the diags will run. You may have a hard drive problem or an issue with the operating system
1helpful
2answers
How to reset to factory default without disc
Step 1. First you will have to restart your computer.
Step 2. During bootup, continuously press the F8 key and you will see the Advanced Boot Options menu.
note.gif OTE: You must press the <F8> key before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Step 3. Select the the Repair your Computer option and hit Enter
Step 4. You will be asked about language and to log on as an Administrator.
Step 5. You will then select Dell Factory Image Restore
Step 6. Select the checkbox for "Yes, reformat hard drive and restore system software to factory condition"
Step 7. Click next and the computer will begin the system restore process which may take some time.
Step 8. When it is finished you will be prompted to restart you machine.
When I start my Dell Inspiron 1501 and enter the password it goes to the Welcome screen and just keeps scrolling and nothing ever happens, it just keeps scrolling
after giving ur password press alt+ctrl+delete then the desktop icon will be apear. set ur windows time and date.if this happen will be come again so change ur cmos bettrey
Blank screen on start up. No dell logo. Only
have u tried resetting it (u may loose it all)
2answers
Dell Inspiron mini10
check if keyboard works during dell logo - try to press F2 or F12 - if no response need to replace keyboard
1helpful
I-INC monitor to use with my Dell Laptop, no signal to monitor?
When Windows logo disappear on the I-INC, do you still see it on the Laptop monitor?
All laptops have function keys to switch the screen between the external monitor (I-INC) and laptop monitor. On your laptop, it is Fn+F8 key. Press them once and wait for 3 seconds, it will switch the image between 2 monitors (external monitor ONLY, laptop monitor ONLY, and both).
During start-up, do not close the laptop cover. Because it may put your laptop into a stand-by mode and turn off the screen. You need to modify this Power Option setting within the Control Panel.
Inspiron 6000
If you purchased your I6000 after 2005, then it still has the PC Restore option. For Dell system with Windows XP, your can restore your computer to factory settings by pressing CTRL+F11 when you see the page after the big DELL Logo. It's a BLACK SCREEN with a blue bar at the top and it has www.dell.com written in white. Usually this screen will show up in between the DELL Logo and Windows Logo.
Grand Canyon Tech
Grand Canyon Tech
