Question about ASUS Computers & Internet
How to check reset signal on ram slot
P8h61
    Habit-Forming:
  • 89 Answers
Their is no way to reset the ram signal. All you can do is remove the cards, install one at a time, and power on the unit. If one works, try another, and so forth. If you get to a ram module that doesn't work. You may need to replace the bad module.
Posted on Jan 16, 2015
SOURCE:
What is max. ram for a systemax syx-p8h61-mlx2 / serial,107477756
2 x DIMM, Max. 16GB, DDR3 1333/1066 Hz Non-ECC, Un-buffered Memory
Jul 24, 2014 | Systemax Computers & Internet
1 ram slot not work
Check Your Bios Settings To Make Shure All The Memory Slots Are On !
Consult The Manual For The PC !
Feb 18, 2014 | ASUS P8H61-M LX LGA1155/ Intel H61B3/...
One ram slot not working
Check below ASUS link if it solves you problem. You can also contact ASUS support. If your problem persists, you have no option other than replacing the board.
ASUSTeK Computer Inc Support Troubleshooting P8H61 LX
Computer build
No Signal means the Monitor is not receiving a connection or communicating with the Video Card. If you placed a Video Card in one of the slots make sure it is pushed in all the way. Your video card is not in correctly or it is faulty.
If you can boot to the Bios or System Setup make sure you have things enabled such as the pci slots, usb ports, the hard drive on Auto so it can configure itself, etc. There might also be a video setting that you need to tweak.
May 10, 2012 | Computers & Internet
Msi board power signal ok.but no ram signal
hi friend..!!!!!!
check and clean your ram..
1) remove your ram and clean it with blank white paper.
2) reinstall ram on another slot.
or
if you using two ram so check them one by one.
hopeyour problem solved
if you find this is helpful for you so please rate me this will encourage me todo more free work..
regards'
sandy
Sep 04, 2011 | MSI K8MM-V Motherboard
HOW TO CHECK RESET SIGNAL ON PCI SLOT OF MOTHERBOARD
you can find out on A15 pin for reset and B16 for clock .
reset singnal have around 5 volt and clock have 1.7 vlt
Mar 15, 2009 | Computers & Internet
No display on IBM motherboard
replace your ram as wwell as cmos battery
Mar 13, 2009 | Computers & Internet
Switched on pc monitor says no signal? The fans and hard drive are spinning but nothing happens ive tried putting xp disc in but thr drive flashes a couple of times then stops.How can i start my pc or cant...
check the memory card, or the ram?! removed the ram ram from the slot? clean the slot of the ram and clean also the memory card by an eraser?!
check also the video card?!!
Feb 26, 2009 | ASUS P5VD2-MX SE Motherboard
Computers & Internet Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
