Does the TV have WiFi enabled? Is it in range of your WiFi router? Is the place where the TV is located a WiFi dead spot? Does the TV see your WiFi router, and is it the strongest signal in the TV's locality? Are your neighbours using the same WiFi channel as you? Have you got the router set to block MAC addresses? Is the TV set to use DHCP? Is the router handing out IP addresses? What security level are you using? Are you putting in the correct WiFi password? The list goes on and on.....
SOURCE: i am unable to connect
Same issue. Samsung 55 inch 8000. Wii component cables plugged in, but it is not recognized.
