Oven doesn't work
Good Afternoon Friend, thank you for allowing me to assist you!
I understand you are experiencing an issue with the oven of your Frigidaire range. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? Do the burners/elements work? With this information I can assist you better in pinpointing the problem.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you! -Z
