First unplug the disposal from the electrical outlet. Do not just shut the switch to the off position.
You will need to drain the water sitting in the trap so place a container under the trap to catch the water.
Loosen the collar on the disposal ( use a small hammer and screwdriver)
Remove the old gasket on the top of the disposal and replace with the new gasket.
Place a little plumber's silicon on the gasket and reinstall the disposal. ( it might be a little difficult due to the new gasket)
Check for leaks and then plug the disposal back into the outlet
SOURCE: sink garbage disposal not working! when I switch
Do you hear a humming sound when you turn it on? If so, you have a clogged disposal. Check on the bottom for the allen wrench location recessed in the middle of the disposal. Insert the proper size allen wrench and you'll be able to rotate the motor back and forth (sometimes difficult at first) and eventually loosen the clog and free up the motor. If you're able to move the shaft/motor easily in the beginning and it still doesn't work you may have a defective disposal. If you want to check more thoroughly you'll need to check to see if you have power at the disposal when you turn on the switch. Use a electrical tester that you can buy at any home improvement store to see if you have power at the disposal. If so, and the motor turns easily when you use your allen wrench, you have a defective disposal and it needs replacement.
SOURCE: shot gun b b in garbage disposal, can't locate to remove. help.
Use vacuum cleaner down into disposal.
Copy following link for general troubleshoot tips:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
If you need further help, Iām available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Yes. it is not hard either...
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
